B16A or B17 head, on a B20 block
Old Jun 16, 2007 | 04:40 PM
votoms888's Avatar
Default B16A or B17 head, on a B20 block
I have access to either a B16 head or a B17 head. Which one flows better? Which one should I use?
Thanks
Old Jun 16, 2007 | 04:52 PM
SkankyEJ7's Avatar
Default Re: B16A or B17 head, on a B20 block (votoms888)
its the same thing dude, but id use a gsr head if it was me. p72 ftw
Old Jun 16, 2007 | 07:43 PM
VTEC2841's Avatar
Default Re: B16A or B17 head, on a B20 block (SkankyEJ7)
GSR head with a minor port.. is by far the best cylinder head. IMO
Old Jun 17, 2007 | 10:05 AM
votoms888's Avatar
Does the B17 GSR head use the same bolt pattern as the B16 for Intake and Exhaust manifolds?
Old Jun 17, 2007 | 11:47 AM
doood's Avatar
been there done that
Default Re: (votoms888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 &raquo;</TD></TR><TR><TD CLASS="quote">Does the B17 GSR head use the same bolt pattern as the B16 for Intake and Exhaust manifolds?</TD></TR></TABLE>
what part of it's the same thing dont you understand?
Old Jun 17, 2007 | 01:04 PM
votoms888's Avatar
Default Re: (doood)
Sorry, just wanted to make sure as the newer GSR heads aren't. Anyways, still a noob.
Old Jun 17, 2007 | 02:30 PM
91' LS-VTEC's Avatar
B16 head/ B17 head..same thing
Old Jun 17, 2007 | 05:46 PM
SiB16A's Avatar
Default Re: (91' LS-VTEC)
if your going to end up building it/porting it. I dont think it really matter.
Old Jun 17, 2007 | 05:48 PM
SkankyEJ7's Avatar
Default Re: B16A or B17 head, on a B20 block (TypeXisMetrosexual)
and notice that using h20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeXisMetrosexual &raquo;</TD></TR><TR><TD CLASS="quote">
present facts.</TD></TR></TABLE>
Old Jun 17, 2007 | 05:56 PM
SkankyEJ7's Avatar
red b16
blue gsr
Old Jun 17, 2007 | 07:19 PM
satitus's Avatar
H2O ???
Old Jun 17, 2007 | 09:46 PM
votoms888's Avatar
Ok, so the B16/B17 head are the same. However, the B18C1 head flows better. Is that correct?
Old Jun 17, 2007 | 09:59 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so the B16/B17 head are the same. However, the B18C1 head flows better. Is that correct? </TD></TR></TABLE>
no. you're not paying attention.
Old Jun 17, 2007 | 11:29 PM
SiB16A's Avatar
Default Re: (doood)
supposively b16 head flows better. Difference is the chambers in the gsr head is smaller hence the compression difference if you get my drift.
Old Feb 10, 2021 | 09:01 PM
Sam Nadeau's Avatar
well if i’m not wrong dude a p72 is 2nd gen gsr 1.8L. 1.7L was the first gen gsr with a p61-ecu
Old Feb 11, 2021 | 07:55 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
The B17 GSR motors used a PR3 head, which is the B16/ITR head. Only the B18C GSR motors had the P72 heads.
P72s heads make more compression, PR3 heads flow more CFM from the factory, especially ITR PR3 heads which have been factory ported.
If you are going to have the head professionally ported most people prefer the GSR head due to chambers and quench design, but ultimately it doesn't matter they will make within 1% of each other when built.
HondaAP1
Apr 19, 2009 12:17 PM
drag-ek
Feb 23, 2006 04:41 PM
LSV_REX
Nov 14, 2005 08:01 PM
0bLiViOuS
Jun 17, 2005 01:10 PM
EFin' Kyle
Jul 26, 2004 10:09 PM
