Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Timing Chain Help!!!
Old Sep 20, 2008 | 10:26 AM
jdm_h22's Avatar
Default Timing Chain Help!!!
Ok so i thought you guys might now what the deal is with this chain. I've currently been building a k24/k20 motor, solely going by the k20 manual. The K20 (rsx) manual says that the timing chain has 3 dark links, which correspond with a tooth on the crankshaft, intake cam, and exhaust cam. Here's the problem. The K24 chain i'm using has two dark links for each cam gear. Which one do i go by? Hopefully you understand what i'm saying. lol the pic should help...
Old Sep 23, 2008 | 10:07 AM
NeKe1point0's Avatar
Default Re: Timing Chain Help!!! (jdm_h22)
hard to tell with that pic because u have 2 links circled in each... but i believe it should be 9-10 between the dark links (for the intake and exhaust marks on cam gears).. clubrsx had a write up with no pics and said it was 9 links between the links but im pretty sure i counted 10. Either way the dark links should line up with the cam gear marks when at TDC.
Old Sep 23, 2008 | 11:51 AM
endlesswinterco's Avatar
Default Re: Timing Chain Help!!! (NeKe1point0)
k20a.org might be helpful place to find it. sorry i dont have an answer but thats a good place to post/search
Old Sep 25, 2008 | 10:15 PM
ITR.#1446's Avatar
Default Re: Timing Chain Help!!! (endlesswinterco)
the dot on your cam shaft should be between the two dark links the rsx manual you are reading is for a k20 chain which has only 3 dots like you described. What oil pump are you using in your build a type s or the k24 pump?
Skeero
Jan 24, 2012 02:13 PM
PremiumPrelude
Apr 8, 2008 09:30 AM
rbanke
May 13, 2006 01:17 PM
gsrteg
Mar 13, 2003 05:13 AM
