2004 TSX - Check Engine Light
Does anyone know what could be causing the Check Engine Light to come on?
At first (for about a month or so) it just flashed when I started the car. It would do that for about a minute or two after the car started. Then it would go out. About two weeks ago it just started staying on.
I get my oil changed regularly, I wouldn't think it would have much to do with that. Plus, there's only 24,000 miles on the care.
Is this something that I need to take to the dealer to have reset or is it something more serious?
Also, if it's just something that needs reset, does anyone know if I can take it anywhere or does it have to go back to the deal?
Thanks in advance.
Thanks in advance.
I think that you turn your car key to second position (just before cranking). Push your trip dial (one on the left on your speedo) in and hold, after 5 seconds or so light should go out...
