Koni & GC
Koni & GC
Im using this car for street its my daily. What is the best spring rate close feeling to stock? I have search and I havent found much info. I heard koni and gc is really good and its cheap compare to others. Deciding to get this but need spring rates suggestion or should I go with other brands. Help please thanks!!
Re: Koni & GC
If the car is your daily driver then I highly recommend the a-spec suspension kit. It lowers the car about 1" and handles a lot better than stock without sacrificing much ride quality. It's $650 shipped brand new from curry acura and it comes fully assembled with the tophats. Bolts right on to a rsx, for an EP3 you're gonna need rsx tie rod ends and shave the rear shock bushings about 3mm. If you're really on a tight budget then get a used DC5 type r suspension from ebay, they usually go for about $350 shipped and is basically identical to the a-spec kit.
