Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
Working on a mid-engine car
Old Dec 20, 2008 | 08:56 PM
fluke702's Avatar
Default Working on a mid-engine car
While I'm not new to H-T, this is my first post in this forum. Just wondering the degree of difficulty for normal maintenance on your cars. I previously owned an Integra GS-R and i've done simple things, change oil/trans fluids, replace my radiator, shocks/springs, even installed my own short shifter with bushings which was a PIA! I know it's not the same, and I'm guessing that most of the owners here have their own specialized NSX-tech that handles all maintenance issues. Is maintenance extremely expensive? I really don't mind, my last car was a GS300 and they charged an arm and a leg for the Timing belt change. I just want to know what I would be getting into should I decide to go the NSX route. Thanks!
Old Dec 20, 2008 | 09:07 PM
Top Ramen's Avatar
I think there are some threads on NSX Prime that go over the costs for routine maintenance. I have not found it to be a difficult car to work on unless you have to R&R the engine, which is kind of a pain without a real lift.
Old Dec 20, 2008 | 11:33 PM
JDM Squad's Avatar
its not as hard as you expect, after buying my 91 nsx with 104k miles. i was told that i had to change out my TB just in case since the previous owner did not do anything for maintenance. so i changed out my TB, water pump, plugs, gaskets, re valved, myself. if you have the time and are willing to learn its easy. if you need help go to www.nsxprime.com and search around, thats what i did. good luck!
Old Dec 24, 2008 | 11:58 AM
NSXRguy's Avatar
Default Re: Working on a mid-engine car
timing belt change will cost you about $1500
maybe thats a hint on what kind of job it is...
Old Dec 24, 2008 | 08:19 PM
Arsenal's Avatar
All I remember about mid engine, was that it takes for ever to cool down. Had an MR2 Turbo, and couldn't touch the engine for a good couple hours! However, uncle has a GT40 and that thing is easy as pie to work on.
CivicMan2011
Apr 8, 2011 12:46 AM
04Si
May 23, 2007 01:36 PM
Tyler1982
Nov 13, 2004 04:05 PM
IntegraGSR321
Nov 7, 2003 09:47 PM
lewylou
Oct 4, 2002 05:04 PM
