Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
Engine Coatings
Old Nov 8, 2007 | 12:59 PM
Ponyboy's Avatar
Painting Masterpieces
Default Engine Coatings
Long story short, a few ordered part glitches are preventing delivery of my baby. In the meantime, I'm thinking of having a few parts ceramic coated:
Oil Shedding:
- connecting rods
- crankshaft
Lubricating coating:
- bearings (for sure)
- valve stems
Anyone have any experience with this? Is the expense worth it (outside of the bearings)? Or is it just throwing money at very minimal gain (less than 1% gain)? It'd be about $600 bones for all of the above.
I've read up on it a bit (potentially biased content) but am interested in getting additional feedback/discussion going. TIA!
Old Nov 12, 2007 | 05:36 AM
ak's Avatar
ak
Default Re: Engine Coatings (Ponyboy)
...(hears a pin drop)
You might as well talk to yourself since TopRamen seems to be away Personally I wouldn't waste the $$ since you are not producing humongous power.
Old Nov 12, 2007 | 07:24 AM
Ponyboy's Avatar
Default Re: Engine Coatings (ak)
I know, I know. But somebody outside of nick has to introduce new content.
I'm thinking just the pistons (domes and skirts) and the bearings. There's some hp to be gained in the oil shedding coatings but perhaps not enough to offset the lubricity and cooling properties of the oil.
Old Nov 13, 2007 | 09:34 AM
prospeed's Avatar
From my experience and from seeing engines over the years i can say that most professional race team use coatings(ceramic or other exotic coatings) The oil shedding is a definate plus as well as the extra protection. It is definately not a black and white mod but might be worth looking into to. Then again $600 can be used elsewhere
Old Nov 13, 2007 | 03:46 PM
Tomcat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">I know, I know. But somebody outside of nick has to introduce new content.
I'm thinking just the pistons (domes and skirts) and the bearings. There's some hp to be gained in the oil shedding coatings but perhaps not enough to offset the lubricity and cooling properties of the oil.</TD></TR></TABLE>
Actually thermal barrier coatings on the piston tops, and anti-friction coatings on the piston skirts are all you need unless you are building a racing engine. Oil- shedding coating inside the valve covers and the oil pan are probably overkill at your build level. Coating the bottom end bearings was not recommended by my engine builder.
Old Nov 19, 2007 | 08:06 AM
Ponyboy's Avatar
Default Re: Engine Coatings (prospeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prospeed &raquo;</TD></TR><TR><TD CLASS="quote">From my experience and from seeing engines over the years i can say that most professional race team use coatings(ceramic or other exotic coatings) The oil shedding is a definate plus as well as the extra protection. It is definately not a black and white mod but might be worth looking into to. Then again $600 can be used elsewhere </TD></TR></TABLE>
Yeah, most do. But again they have the option of rebuilding their engine as much as they can afford. The negative, as I've come to read, in the oil shedding coatings is that the oil is used as a key way to extract heat in the recepricating parts and I'm not sure I want to dilute the oil's effectiveness in that area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomcat &raquo;</TD></TR><TR><TD CLASS="quote">Coating the bottom end bearings was not recommended by my engine builder.</TD></TR></TABLE>
Did your engine builder give a specific reason why?
Old Nov 20, 2007 | 04:20 PM
Tomcat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">...Did your engine builder give a specific reason why?</TD></TR></TABLE>
Sorry about the delayed response; I'll call him tomorrow and ask him.
Old Nov 27, 2007 | 08:30 AM
King V's Avatar
Probably because you want bearings to retain oil, not shed oil.
Old Nov 27, 2007 | 08:41 AM
Ponyboy's Avatar
Default Re: Engine Coatings (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">Probably because you want bearings to retain oil, not shed oil.</TD></TR></TABLE>
Indeed, you do. That's why we were talking about dry film solid lubricating coatings on the bearings.
Old Nov 27, 2007 | 08:48 AM
King V's Avatar
Ah. The extra protection in case something bad happens.
Hondata56
Feb 24, 2019 03:47 PM
Ponyboy
Nov 10, 2007 09:01 PM
Ponyboy
Nov 9, 2007 10:24 AM
O16581724 5 2 5
Jun 1, 2006 09:13 AM
ThatsMyEG
Aug 19, 2005 07:19 PM
