Yet another header post
Old Feb 4, 2002 | 07:57 PM
Taedium's Avatar
Default Yet another header post :-)
I'm looking into getting the best header I can for under 350-400 dollars. I'm leaning towards the DC JDM 4-1 given the numbers from the great header test. I'm wondering which is better, the ceramic or the stainless? Which weighs more and are there any performance differances? Which was used in the Header test, anyone know? Anybody know of a good place to buy them if these are indeed the best for the money?
Thanks
john
Old Feb 4, 2002 | 08:06 PM
SMSP's Avatar
Default Re: Yet another header post :-) (Taedium)
A stainless version of the DC JDM header was used in the header test.
Old Feb 4, 2002 | 08:42 PM
Pinhead's Avatar
New User
Default Re: Yet another header post :-) (SMSP)
Hi SMSP how long will it take to receive your header when I order it.....and does it have descent ground clearence bc i scraped my jdm 4-1 once or twice and im on H&R sport springs
Old Feb 4, 2002 | 08:54 PM
SMSP's Avatar
Default Re: Yet another header post :-) (typerman1358)
It's funny that you should ask about ground clearance since I'm working on drawings right now to try a maximize clearance on an ITR header for another H-T member right now, but he needs to keep the ITR tranny/block support bracket. My current ITR header has one tube that hngs lower than the ITR JDM 4-1 but the other 3 are tucked up close to the oil pan. Now if you are willing to do away with the aluminum bracket and get a GSR flywheel cover, I can build you the GSR style header to be very close to being equal to the low spot on the oil pan, it just depends how much stuff (brackets, etc.) you want to keep down there.
If you want to keep the bracket I can still build the GSR style header (4 flat tubes) and when used with my spec'd Moroso pan there will be more ground clearance. But I'm not sure if you want to spend the extra $ on that pan and the required pick up.
Delivery time is running about 2-3 months right now.
[Modified by SMSP, 9:58 PM 2/4/2002]
Old Feb 5, 2002 | 07:25 AM
Pinhead's Avatar
New User
how much farther does that one piece dip down compared to a jdm 4-1...bc my jdm 4-1 only scrapes towards the very front of the car..and has only scraped once or twice to my knowledge and nothing big..if it only hangs like 1/4inch lower than ill just get the type R one...oh yea and how much are these headers again..im me if you don't want to post that
Old Feb 5, 2002 | 07:28 AM
Warren's Avatar
Wrong-Way Wang
Well I very well can't have my nice new header scraping on track curbing now can I?
Warren, who will finally have a non-stock exhaust
Old Feb 5, 2002 | 07:37 AM
Lip's Avatar
Lip
Default Re: Yet another header post :-) (Warren)
why is it a concern regarding that flywheel cover? pull it off or put a scrap piece of tin in its place bent upright
Old Feb 5, 2002 | 09:28 AM
AJ PwR's Avatar
TypeONE .....better quality and performance.
Old Feb 5, 2002 | 11:39 AM
Stock-DC2's Avatar
New User
For under $350, the JDM DC 4-1 would be your best choice. But just make sure your car isn't lower too much, because you will bottom out and dent it in no time.
Old Feb 5, 2002 | 12:01 PM
tecnic1's Avatar
Default Re: Yet another header post :-) (AJ PwR)
save the extra $200 and get a header you'll still admit you own in a few months.
Old Feb 5, 2002 | 12:12 PM
Gansan's Avatar
Default Re: Yet another header post :-) (Lip)
That thicker cover is an engine block stiffener that helps the block stay straight at high rpm.
Old Feb 5, 2002 | 12:48 PM
garagespecial
Guest
Posts: n/a
i second that...
TYPE
O
N
E
love it every since i installed it (4-1 design)
aj-racing!
Old Feb 5, 2002 | 01:01 PM
DutchITR1689's Avatar
I wonder if this is an advice to the fellow forum members or plain advertisement.
Old Feb 5, 2002 | 01:12 PM
Blade's Avatar
New User
Is any of the "TypeONE" stuff you sell actually make in Japan by the real TypeONE company? or do you just make your stuff in Taiwan/Hong Kong and put the TypeONE name on it? just curious
Old Feb 5, 2002 | 02:14 PM
sgT's Avatar
sgT
Default Re: Yet another header post :-) (Gansan)
LOL
I dont see how....
But to answer Lips question, some racing bodies dont allow removal of the brace
Old Feb 5, 2002 | 04:28 PM
NAB20C5's Avatar
Default Re: Yet another header post :-) (sgT)
LOL
I dont see how....
serious? that i didn't know...care to share eg.) of what "racing bodies" you may be referring to?...just curious, never knew, and of course why would it matter?
Old Feb 5, 2002 | 09:25 PM
SMSP's Avatar
Default Re: Yet another header post :-) (NAB20C5)
NAB20C5, The Honda Challenge folks won't lets us remove that big old aluminum bracket bracket. Not even sure if we can mod it. We can mod the oil pan but can't replace the pan with a non stock unit.
typerman1358, By removing the bracket I can have the 4 tubes no lower than the oil pan, with the 1 piece header and just a hair below with the fully adjustable version. The ITR JDM 4-1 hangs about 3/4" below the lowest point of the pan and the SPOON around 1-1/4", not sure on the DC JDM.
[Modified by SMSP, 10:28 PM 2/5/2002]
Old Feb 6, 2002 | 01:14 AM
That bracket is called "Engine stiffener" in my Shop Manual (Euro edition)!!!!!!
Old Feb 6, 2002 | 03:44 AM
SMSP's Avatar
Default Re: Yet another header post :-) (EuroITR1689)
The GSR has 2 "L" shaped brackets with a sheet metal cover and the CRV has just a sheet metal cover no brackets (I haven't looked at the new CRVs).
Old Feb 6, 2002 | 03:46 AM
I think only the Type Rs (ITR and CTR) has this engine stiffener.
BTW. My Shop Manual is an ITR only manual since there are no other Integras here in Europe.
[Modified by EuroITR1689, 1:48 PM 2/6/2002]
Old Feb 6, 2002 | 01:08 PM
Taedium's Avatar
Default Re: Yet another header post :-) (DC2-Rated)
Is there a good header that is safe to use on 1.5 inch lowered ITR?
Old Feb 6, 2002 | 02:58 PM
mafay2's Avatar
New User
I think the Toda header would give the best ground clearance out of all the JDM style header, since it is 4-2-1 design.
tempsohc
Nov 18, 2007 10:01 AM
93Civic_hb
29
Apr 24, 2004 07:48 AM
aclw2
Apr 6, 2004 05:48 AM
ls95hatch
Mar 25, 2003 05:59 PM
