Where does this plug go?
Old May 11, 2005 | 06:39 AM
AntonioH's Avatar
Default Where does this plug go?
After assembling my JDM front end I had this plug that goes somewhere. It may be related to my A/C problem.
Old May 11, 2005 | 07:11 AM
jmk2888's Avatar
Default Re: Where does this plug go? (AntonioH)
Looks like the plug that goes to the Washer Fluid Motor.
Old May 11, 2005 | 07:19 AM
m R g S r's Avatar
i thought those were two wire.....
Old May 11, 2005 | 07:22 AM
AntonioH's Avatar
Washer fluid works fine.
Old May 11, 2005 | 09:04 AM
Black R's Avatar
25 Year Member
extra plug.
Old May 11, 2005 | 10:07 AM
AntonioH's Avatar
I'm sure it goes to something.
Old May 11, 2005 | 10:32 AM
b19coupe's Avatar
Looks like the fog light connector.
Old May 11, 2005 | 10:39 AM
citrus3000psi's Avatar
A little more information might be helpful as in where the other end of the wire is terminating. Is it going into a wire loom? It might be a plug for a fan up front, but most harness plugs look the same so its hard to tell.
Old May 11, 2005 | 12:18 PM
ITR.#1446's Avatar
Default Re: (citrus3000psi)
it goes to the fogs i recently took mine off and remember what it looks like it should be running off the headlight harness
Old May 11, 2005 | 12:34 PM
iperez's Avatar
This is your OEM fog light connector.
Old May 11, 2005 | 12:41 PM
TypeRobert's Avatar
Default Re: (iperez)
*Food for though*
if its the fog light connecter shouldnt you have ended up with two identical connectors on each side????
Old May 11, 2005 | 01:09 PM
justahobbie's Avatar
Default Re: (slperhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slperhybrid &raquo;</TD></TR><TR><TD CLASS="quote">*Food for though*
if its the fog light connecter shouldnt you have ended up with two identical connectors on each side???? </TD></TR></TABLE>
good thinking...is there another?
Old May 11, 2005 | 01:27 PM
ITR.#1446's Avatar
Default Re: (justahobbie)
no its just runs off of the one side....it goes to the drivers side fog light then across the lower rad to the passnger side
Old May 11, 2005 | 02:05 PM
Comp97GSR's Avatar
BUTT-PLUG. Shame on me, but I didn't read every reply. Is that a 1 wire connector?
Old May 11, 2005 | 02:44 PM
AntonioH's Avatar
It's a 1 wire connector. It may be for OEM foglights. I don't know.
Old May 11, 2005 | 02:46 PM
Kenso's Avatar
HT White Ops
Default Re: (ITR.#1446)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">no its just runs off of the one side....it goes to the drivers side fog light then across the lower rad to the passnger side</TD></TR></TABLE>
Correct.
Old May 11, 2005 | 02:51 PM
AntonioH's Avatar
I guess there's nothing to worry about. Thanks for the responses everybody.
Old May 11, 2005 | 07:57 PM
Taristin's Avatar
'tis the relay wire for the fogs. Runs to the dash so you can plug a switch to it.
*answering the question that has already been answered*
Postcount +1
civicfan18
Jun 16, 2017 05:31 AM
moaterboaink1ng
Nov 24, 2012 10:25 AM
fms1day
Nov 19, 2005 07:11 PM
NBPcivic07
15
Dec 28, 2004 11:38 AM
