what Header for high compression Jun3 setup??
Old Apr 1, 2002 | 05:57 PM
Pinhead's Avatar
New User
Default what Header for high compression Jun3 setup??
I was thinkin SMS, but the Toda looks quite nice as well...but I'd assume Toda's are made to work with Toda cams and SMS ARE CUSTOM
Old Apr 1, 2002 | 07:17 PM
t's Avatar
t
Default Re: what Header for high compression Jun3 setup?? (Pinhead)
Why not JUN header as that was what they recommend with their cams.
Old Apr 1, 2002 | 07:19 PM
TypeR0149's Avatar
Default Re: what Header for high compression Jun3 setup?? (t)
Keith go with a 99 civic si header
Old Apr 1, 2002 | 07:23 PM
Pinhead's Avatar
New User
Default Re: what Header for high compression Jun3 setup?? (Vegeta)
Thanks Mike, you are wise beyond your years as usual lol
Old Apr 1, 2002 | 08:07 PM
GokuSSJ4's Avatar
with the SMS or Hytech and some good tunning youll have some nice #'s
Old Apr 1, 2002 | 08:58 PM
Big Teggie's Avatar
Default Re: what Header for high compression Jun3 setup?? (Spoon1)
I am goin Jun 3's also and i am considering getting a toda header. I hear it performs well on any high compression setup.
Old Apr 1, 2002 | 09:27 PM
Pinhead's Avatar
New User
Default Re: what Header for high compression Jun3 setup?? (Big Teggie)
that's what I hear...it's either toda or SMS I'll have to make my decision quickly
anyone else have any input..just chime right in
Old Apr 1, 2002 | 09:32 PM
MackSpeed-616's Avatar
jun3 + smsp header = 206 hp!!!
Old Apr 1, 2002 | 10:17 PM
AllMotorMadness's Avatar
SMS
Old Apr 1, 2002 | 11:54 PM
SIINSI's Avatar
Default Re: what Header for high compression Jun3 setup?? (TurboR616)
I got that with a JUN header and STOCK Bottom end
Miguel
Old Apr 2, 2002 | 12:18 AM
itr1236's Avatar
Default Re: what Header for high compression Jun3 setup?? (SIINSI)
Get the JUN header!!!! That thing is desgined for their cams. I tested the hytech header on my car and it didn't do jack it actually lost power in the mid-range, and i don't think that it is worth the hassle of making everything fit right, not to mention that it is 3-400 dollars more. The JUN header bolts right up and works awesome with their type 3s.
I don't mean to rag on the hytech header, it is a very good header, and it will make good power. It's just it was so built up while the JUN header was so ragged on, and then when it came down to it, it actually lost power. JUN really knows what they are doing they designed all of their parts to work together to make the most power.
Old Apr 2, 2002 | 12:49 AM
SIINSI's Avatar
Default Re: what Header for high compression Jun3 setup?? (itr1236)
I agree, their ECU kicks *** as well
Their products work wonders in conjunction with eachother.
Miguel
Old Apr 2, 2002 | 06:39 AM
Pinhead's Avatar
New User
Really...I would've figured toda AND sms would've out performed the Jun header considering all the dyno plots I've seen...and that sms is fully adjustable?
Old Apr 2, 2002 | 07:21 AM
itr1236's Avatar
I also would have agreed with you right after the great header test. That is one of the reasons that I tried the Hytech header. True I haven't tested it against the Toda or the sms, but all that I have heard over and over again is that header is designed SPECIFICALLY for the type 3 cams. I think that on a stock motor there are other headers that will make more power, but when you start changing things like cams, that is when the JUN header really starts making power.
Old Apr 2, 2002 | 09:04 AM
Pinhead's Avatar
New User
ok, if Jun header is designed for the Jun cams...don't you think Dave's(SMSP) header would work well too considering it's fully adjustable? and it's custom made?
Old Apr 2, 2002 | 12:34 PM
sgT's Avatar
sgT
Yeah, but you also had an intake and exhaust. TurboR616 is still running on stock.
Old Apr 3, 2002 | 08:46 AM
Pinhead's Avatar
New User
Default Re: what Header for high compression Jun3 setup?? (sgT)
any other opinions? Jun, toda, sms????
Old Apr 3, 2002 | 09:01 AM
SIINSI's Avatar
He also has oversized pistons.... I'll call that even
Miguel
Old Apr 3, 2002 | 09:05 AM
sgT's Avatar
sgT
lol
Old Apr 3, 2002 | 09:13 AM
Big Teggie's Avatar
If i switch from my old jdm 4-1 to a toda header, will i really feel a diference, is it worth teh extra 500? Especially if i am goin bigger cams like jun3's?
Old Apr 3, 2002 | 09:16 AM
sgT's Avatar
sgT
the honda 4-1 is definitely too small for any aftermarket cam setup
Old Apr 3, 2002 | 09:42 AM
Lip's Avatar
Lip
don't make me post photos of it steve...rather...nuprin boy
Old Apr 3, 2002 | 09:44 AM
Pinhead's Avatar
New User
Default Re: what Header for high compression Jun3 setup?? (Lip)
come on guys...the choices are toda, jun , or sms
Which would you guys choose for a lowered street car? on jun3 cams and 12.3:1 compression
sgT's Avatar
sgT
post away
I bet had you had a better header you would have run 12s with your old setup
Old Apr 3, 2002 | 09:45 AM
Lip's Avatar
Lip
i bet your right
rs*r vs jdm 4-1 (added msd at same time with jdm)
