What engine code is this?
Old Jun 9, 2002 | 08:15 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default What engine code is this?
Blink.......Blink.......Blink.......Blink.......Bl ink.......Blink.......Blink.Blink.Blink.Blink.Blin k. I think it's code 74, what's that code mean?
Old Jun 9, 2002 | 08:21 PM
NWPNOMORE's Avatar
Banned
Default Re: What engine code is this? (01PYTypeR#1140)
random misfire in cylinder 4.
Old Jun 9, 2002 | 08:25 PM
Default Re: What engine code is this? (NWP4LIFE)
What could've caused that? Are you sure thats the code, because the car is running fine. Could my timing be too low.
Old Jun 9, 2002 | 08:26 PM
NWPNOMORE's Avatar
Banned
you are probably not reading the code right.
http://www.sonic.net/~abwc/jeff/b16_...rror_codes.htm
Old Jun 9, 2002 | 08:28 PM
integRated109's Avatar
http://www.hybrid-k.com/tech/codes.html
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Looks like 65.
Old Jun 9, 2002 | 08:30 PM
It could be code 65 my Blinks are up top. what could cause code 65?
Old Jun 9, 2002 | 08:33 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
65 - Secondary Heated O2 sensor
Probable cause:
Open or short in Secondary H02S heater circuit
Can someone put this into english for me (Secondary Heated O2 Sensor Circuit) does this mean bad cat. or O2 sensor or what.
Old Jun 9, 2002 | 08:35 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
This is the 'cause!!
Carsound Cat. #54006, 2-1/2" SS Straight Pipe
Old Jun 9, 2002 | 08:36 PM
NWPNOMORE's Avatar
Banned
Default Re: What engine code is this? (DB8GSR)
haha, yeah that will do it.
Old Jun 9, 2002 | 08:37 PM
Had this set up for over a year now and never had this problem so that doesn't hold water.
Old Jun 9, 2002 | 08:52 PM
PrecisionH23a's Avatar
65 sounds liek the code. maybe your 02 sensor went to hell?
Old Jun 9, 2002 | 09:13 PM
sgT's Avatar
sgT
NO, IT WONT DO IT.
O2 sensor heater circuit means there is a problem with the PHYSICAL ELECTRICAL
CIRCUIT for the heater on the oxygen sensor.
Old Jun 9, 2002 | 09:35 PM
Default Re: What engine code is this? (sgT)
NO, IT WONT DO IT.
I wonder if it's covered under warranty.
Old Jun 9, 2002 | 09:39 PM
sgT's Avatar
sgT
Possibly, this is assuming you read the code properly and that they arent bothered
by the fact you replaced your cat.
lukman16
Apr 15, 2009 11:21 AM
phyzJunkieCivic
Mar 18, 2006 02:44 PM
