weird noise. possibly the diff???
Old Nov 30, 2007 | 04:58 PM
itrcbr's Avatar
Default weird noise. possibly the diff???
Well I have a 2001 integra type R. the car and transmission only have 40,000 miles on them (motor has only 2000, just rebuilt). car started making a clicking noise, that progressively worsened rather quickly. drivers side wheel bearing had a little play so i replaced it and that didn't solve the problem. axle looked good, but i replaced that with a brand new one, and that did not solve the problem.
definately not the motor, because the noise still persists when i shut the motor off, and let the car free wheel. Sounds like it is coming from the left side of the car but it is hard to tell.
does anyone have any way i can distinguish whether it is the differential or something else, or any other possibilities.
thanks in advance
Old Nov 30, 2007 | 05:13 PM
iheartintegras's Avatar
Sounds like them same problem I'm having man. I've taken it to two shops both told me different things. I changed tranny fluid, didn't help at all. New axles, no help. I'm leaning towards the lsd. Do you only hear it when you're turning?
Old Nov 30, 2007 | 05:15 PM
btw I've made a few posts on here asking for help. But I guess no one else has had this problem because I didn't get many replies
Old Nov 30, 2007 | 05:23 PM
itrcbr's Avatar
Default Re: weird noise. possibly the diff??? (itrcbr)
thanks maybe i will try the motor rebuild thread.
I hear the noise when i go in a straight line as well. transmission fluid is brand new. im going to drain the transmission oil and inspect for metal shavings. only other possibility besides the LSD i can think of is maybe the intermediate shaft. spins good by hand though.
it seemed to get worse after i ripped around a few corners. thanks for your answer this is really frustrating.
Old Nov 30, 2007 | 05:25 PM
I know it man, mine has been doing it for like 4 months now. I gotta turn my music up to ignore it. Did you do something to your car then it starting doing it? Or was it out of no where?
Old Nov 30, 2007 | 06:06 PM
itrcbr's Avatar
pretty much out of no where. i dont know wtf. if i can find any information i will let you know.
Old Nov 30, 2007 | 06:17 PM
Yeah man please keep me posted. I'm happy to know that I'm not alone with this problem
Old Nov 30, 2007 | 07:13 PM
R.Kelley's Avatar
Input shaft bearing maybe?
Old Nov 30, 2007 | 11:14 PM
what's that?
Old Dec 1, 2007 | 07:18 AM
itrcbr's Avatar
input shaft bearing in the transmission?
Old Dec 1, 2007 | 07:13 PM
J.Berta's Avatar
this is weird. My car is doing the same crap. I just in stalled a new set of 2.9 DSS axles in and my car is doing the same thing as you're describing. I went to the track last night and my wife said she could her some poppingnoise when i pulled in from tech. And tonight i heard it for myself while turning sharp to the right in Walley World. I'm goin to have to inspec this tomorrow. Hopefully its not the diff!! And not the axles either!! Have you guys figured whats up with your cars??
Old Dec 1, 2007 | 07:26 PM
Nope still trying to figure my **** out..
Old Dec 1, 2007 | 07:33 PM
I noticed my lower ball join is leaking a little.
#4 in picture
http://www.sonsacuraparts.com/...dIrno=
Old Dec 1, 2007 | 10:02 PM
itrcbr's Avatar
Default Re: (iheartintegras)
i wouldn't think it could be the ball joint. my car does it when i am going straight as well and that wouldn't be moving. i tried asking in another tech forum, but got no response thus far.
I guess my next option is to take it to a shop. maybe i can pay them to diagnose it because i sure cant afford to have them fix it. i actually wanted to sell the car, but i cant if it is making this noise. Mine got worse quick, after i took a hard turn. pretty odd. i have only replaced wheel bearing and axle on the driver side. possibly the other side i guess.
please do let me know if either of you guys figure anything out
Old Dec 2, 2007 | 09:27 AM
itrcbr's Avatar
this is what i was told to do in the tech thread. not a bad idea! I am going to try this in two weeks, as soon as finals are over. i can't deal with this car anymore right now.
"put the car properly on jack stands and run it...while under the vehicle listen for the noise with a mechanics stethoscope or pry bar...then get back to us"
Old Dec 2, 2007 | 09:56 AM
my mechanic did that... Nothing. My noise only happens in turns and while giving it throttle.
Modified by iheartintegras at 9:19 PM 2/6/2008
Old Dec 2, 2007 | 10:00 AM
JjuuN R's Avatar
Default Re: weird noise. possibly the diff??? (iheartintegras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartintegras &raquo;</TD></TR><TR><TD CLASS="quote">my mechanic did that... Nothing. My noise only happens in turns and while giving it throttle.
I'm getting a popping and clunking sound too. I think that might be the lower ball joint</TD></TR></TABLE>
Those are symptoms of a bad CV joint. COULD possibly be a lower ball joint problem, but your description points towards a CV...
Old Dec 2, 2007 | 05:21 PM
I replaced my leaking driverside axle. I think my passenger side is fine
Old Dec 2, 2007 | 05:50 PM
J.Berta's Avatar
Did some investigating on mines, and it sounds like its the driverside axle. It sucks, they are brand new DSS's. They've only been in the car for 3 days!!
Old Dec 2, 2007 | 05:58 PM
Try replaceing it and get back to us!!
What's your's sound like?
Old Dec 4, 2007 | 01:31 PM
J.Berta's Avatar
Will be do wrench turning tomorrow. Will let you guys know whats up with my situation. I still say its the axle. I didnt have this popping/clunk noise until i changd to the DSS axles. But it could just be a bad joint in the axle.
Old Dec 4, 2007 | 01:38 PM
Old Dec 4, 2007 | 06:09 PM
citrus3000psi's Avatar
If the car is on and not moving (in neutral) with the clutch in do you hear the noise? Does the noise come on when you let out on the clutch?
Old Dec 4, 2007 | 06:12 PM
I only hear mine when turning and giving the car throttle
Old Dec 4, 2007 | 06:39 PM
Its either the axles, diff or wheel bearings.
Theres nothing else that I know of. In the helms there is a way to check the diff. not sure if this will help you but its one more idea.
