VTEC problems
Old Dec 6, 2004 | 06:05 AM
94_civic_si_00_ITR's Avatar
Default VTEC problems
I installed a 00 jdm integra type r into my 94 civic si this weekend and am having some vtec problems. It sounds like the vtec is kicking in @ 5k like it should but it doesn't pull any harder. I think that it might be the back pressure on my exhaust because the where my old exhaust systems mates to the integra exhaust (under the firewall) we had to put a temporary connection (two bolts with big washers) so it leaks a pretty good bit. Does this sound like it could be the problem? Also am i going to need to get a bigger radiator? I would like to avoid putting in the integra one because i would have to lose my ac condenser.
Old Dec 6, 2004 | 06:14 AM
1GreyTeg's Avatar
Default Re: VTEC problems (94_civic_si_00_ITR)
You're in the wrong forum.
You'll get the help you need here:
https://honda-tech.com/zeroforum?id=18
Old Dec 10, 2004 | 10:34 AM
b16racer23's Avatar
did u ever fix ur probelm because im having the same problem with my car
Old Dec 10, 2004 | 10:42 AM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_civic_si_00_ITR &raquo;</TD></TR><TR><TD CLASS="quote">I installed a 00 jdm integra type r into my 94 civic si this weekend and am having some vtec problems.</TD></TR></TABLE>
How did you fit a complete car into the engine bay of your hatchback?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_si_00_ITR &raquo;</TD></TR><TR><TD CLASS="quote">I think that it might be the back pressure on my exhaust because the where my old exhaust systems mates to the integra exhaust (under the firewall) we had to put a temporary connection (two bolts with big washers) so it leaks a pretty good bit. Does this sound like it could be the problem?</TD></TR></TABLE>
Do bears **** in the woods? Instead of getting everything in there at the speed of light in time for the weekend street races (g3y), you should do the job properly. Where did you aquire the engine?
Brandon - who didn't build his bottom end and got 0wn3d by his T3/T67
Kyles ej1
15
Dec 10, 2004 12:25 PM
94_civic_si_00_ITR
Dec 9, 2004 02:59 PM
JDMb16ef
Oct 24, 2004 07:10 PM
SWEETBETTY
29
May 20, 2004 02:15 AM
J-balint-k
Mar 20, 2004 07:40 PM
