Vtec issue. HELP!
Old Mar 4, 2008 | 09:17 PM
Bauertegra's Avatar
Default Vtec issue. HELP!
I just recently bought a b18c JDM type-r and swaped it into my 96ls.
I ran direct connections to the Vtec solenoid and knock sensor. The engine came with a ECU and everything is connected properly. I believe its a p72 or p98
The car is ground and no CEL is on.
Oil is full and there are no dents on the pan.
Vtec worked initally when I first ran the car. But it comes and goes everytime i stop and start the car. It is warm but my tempature guage seems to not work correctly. I unplugged the solenoid while the car was running and the CEL came on. I tested the solenoid by running 12v to it and it clicked. I am checking if the solenoid is clogged tomorrow but other then that I have no idea what could be my problem.
Help!
Old Mar 4, 2008 | 09:36 PM
Bauertegra's Avatar
Default Re: Vtec issue. HELP! (Bauertegra)
The engine came with an APEX grounding kit. I did not use it in the swap and the car runs fine. Would that kit be my problem?
Old Mar 5, 2008 | 12:38 AM
Cheeze's Avatar
Try changing out your thermostat. The ecu is reading the temp as low so it wont engage into vtec.
Old Mar 5, 2008 | 02:13 PM
Bauertegra's Avatar
Well I took the solenoid off and cleaned it out. Bought a new Thermastat but vtec was working all day when the car was warm. I guess it fixed itself over night.
Old Mar 6, 2008 | 12:14 AM
silver j's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bauertegra &raquo;</TD></TR><TR><TD CLASS="quote">The engine came with an APEX grounding kit. I did not use it in the swap and the car runs fine. Would that kit be my problem?</TD></TR></TABLE>
that is just a capacitor and has nothing to do with the workings of your car
XxfatlacexX808
Mar 12, 2013 07:18 AM
firstb16swap
Oct 10, 2011 09:18 PM
tthoj
26
Feb 4, 2010 04:41 AM
stevil_knevil
Oct 26, 2008 04:55 PM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
