VTEC is hesitating/sputtering
Old Jun 4, 2003 | 05:19 PM
Nate B's Avatar
Default VTEC is hesitating/sputtering
For the last two days I've noticed that when my cams engage VTEC, there is a very noticable lag, I can hear and feel it change over, then it dies down, then picks up, then dies down. Pretty much all the way through the RPM range. First thing I obviously did was check my oil, which I'm almost due for a change, but does not seem to be the culprit. Then I set my VAFC to display VTi and VTo, both show ON during the whole process, neither go to OFF when I feel the hesitation. I'm really confused as to what the culprit could be and don't know what else to look for. I tuned my fuel curve appropriately on the dyno and adjusted my camgears to +4in -2ex. This was about six months ago and haven't had any issues since. The only thing I've done to the car since is a Spoon header, Carsound cat, and T1R/N1 exhaust. Could the improved flow have thrown all my fuel settings off to cause this? I'm pretty much clueless and could use some advice, suggestions, etc.....Thanks guys
Old Jun 4, 2003 | 05:38 PM
TypeR 01 886's Avatar
Default Re: VTEC is hesitating/sputtering (Nate B)
first off I would say that it has to do with your oild pressure being down
Old Jun 4, 2003 | 05:40 PM
Nate B's Avatar
Default Re: VTEC is hesitating/sputtering (TypeR 01 886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">first off I would say that it has to do with your oild pressure being down</TD></TR></TABLE>Oil level is not signifigantly low, maybe the pump is going? I doubt it, at 30K miles?
Old Jun 4, 2003 | 05:56 PM
Chris N's Avatar
I was going to say erl also.
Old Jun 4, 2003 | 06:32 PM
DarthLuder's Avatar
New User
Maybe its just a violent vtec cross over.
Come on guys, help my friend out.
Old Jun 4, 2003 | 06:57 PM
Nate B's Avatar
Default Re: VTEC is hesitating/sputtering (ITR GURU)
crossover is at 5500
Old Jun 4, 2003 | 06:59 PM
sgT's Avatar
sgT
get an oilpressure reading.
Old Jun 4, 2003 | 07:06 PM
2k1_ITR_0736's Avatar
Default Re: VTEC is hesitating/sputtering (sgT)
check your o2's
Old Jun 4, 2003 | 07:09 PM
Nate B's Avatar
Default Re: VTEC is hesitating/sputtering (2k1_ITR_0736)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1_ITR_0736 &raquo;</TD></TR><TR><TD CLASS="quote">check your o2's</TD></TR></TABLE>no codes being thrown, but i haven't physically checked them.
Old Jun 4, 2003 | 09:46 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Possibly distributor coils. My went bad at around the same mileage. Caused hestitation mis-firing usually only noticeable at high rpm.
Old Jun 4, 2003 | 10:09 PM
JustLooking's Avatar
Hi,
When was the last time you changed your oil? Mine was like that when I drove it past the 3k mile interval. The oil was extremely dirty and after I changed it, the car ran fine.
Old Jun 5, 2003 | 01:35 AM
JdmHondaOnly
Guest
Posts: n/a
Default Re: VTEC is hesitating/sputtering (ActiveAero)
You're right ActiveAero. I can almost guarantee the distributor has taken a crap. I know from actual experience. One of the things that actually destroys the coil is bad spark plug wires. They tend to ground out on the valve cover and goes straight to the infamous distributor. To prevent it from happening again is to change out wires and use thicker\better conductor ground wire from valve cover to chassis. If you get real expensive wires, each wire even has it's own ground usually bolted on to the exhaust manifold\header.
Old Jun 5, 2003 | 02:16 PM
Nate B's Avatar
Default Re: VTEC is hesitating/sputtering (JustLooking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustLooking &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
When was the last time you changed your oil? Mine was like that when I drove it past the 3k mile interval. The oil was extremely dirty and after I changed it, the car ran fine.</TD></TR></TABLE>I change mine every 2500 miles, and was a little low yesterday, I changed today and the problem still persists. Maybe my distributor has crapped out. I'm off work for the next 4 days so I'll do some experimenting. Thanks everyone for the replies
Old Jun 5, 2003 | 05:38 PM
Ben-VTEC's Avatar
This kind of problem just happened in my GS-R, the problem was that these connectors or something inside the distributor had come loose. When it happend it my car the tach would bounce all over the place.
ShuaiGuy
Jun 8, 2004 11:10 AM
ShuaiGuy
Jun 7, 2004 06:15 AM
turbodsmpower
Mar 29, 2003 04:25 PM
Ignitecivic
Jan 15, 2003 08:10 PM
glock
Jun 4, 2002 02:58 PM
