VAFC setting
Old Jun 25, 2002 | 09:21 AM
rbf351's Avatar
Default VAFC setting
i got a VAFC last night, and if someone can help me with the setting.
it's a 2000 Si
i have CTR cams, CTR ECU, JDM ITR 4-1 Header, ITR intake manifiold, ITR CAI
i lowered the VTEC crossover, but don't know what to do for the fuel setting, and help is great
Old Jun 25, 2002 | 09:35 AM
Nate B's Avatar
Default Re: VAFC setting (rbf351)
here we go again. Not to sound like an *******, but you need to enter your own settings through dyno tuning. Even if someone has the exact same setup as you every motor is different and environment plays a big role too. Try doin a search on V-AFC topics and you'll see this has been answered over and over again.
Old Jun 25, 2002 | 09:37 AM
rbf351's Avatar
Default Re: VAFC setting (KILLERB18)
i did a few seaches, i just want to see/get an idea what some people settings are, so i can play around with it
Old Jun 25, 2002 | 09:39 AM
sneakychaos's Avatar
-50 across the board.
(Its a joke.)
Old Jun 25, 2002 | 09:40 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Forget it. The only way to set it is on a dyno while using a wideband O2 sensor.
Getting settings from someone else at best won't work for you and at worst will blow your expensive motor to kingdom come. Every motor is didfferent and you need need to find the right settings for you by tuning it the right way.
Before you come back with some kind of retort, keep in mind that by not telling you what to set it at we ARE helping you out.
Old Jun 25, 2002 | 12:06 PM
JoshRambo's Avatar
Default Re: VAFC setting (newt2)
if you did a search you would have found out that nobody would give other people numbers. just look at it till you get a chance to get on the dyno.
Old Jun 25, 2002 | 01:30 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: VAFC setting (Gravity)
ohboyherewegoagain....
As has been suggested above, leave it zero'd for now. Tune on the dyno. Unless you're that damn good (and I only know one, maybe two people who are), you will do more harm than good by playing with the settings without rollers.
Old Jun 25, 2002 | 03:25 PM
Malice's Avatar
New User
Default Re: VAFC setting (Splat)
this is ridiculous. geez guys. why is everyone so paranoid about playing with the VAFC?! i do all the time. as long as u know ur perameters then its ok.
Old Jun 25, 2002 | 03:30 PM
Mike M's Avatar
Founding Member
Default Re: VAFC setting (MaliceGSR)
2 5 and 10
ricanem1
Nov 29, 2006 06:57 AM
gsrx
Nov 24, 2004 02:12 PM
CarAudiophile
May 6, 2004 02:58 PM
rbf351
Jun 26, 2002 08:46 AM
azntyperrr
Nov 12, 2001 08:11 PM
