Upper Strut Mounts
Old Oct 8, 2002 | 05:17 AM
acuracy389's Avatar
New User
Default Upper Strut Mounts
Hey! My upper strut mounts are gone due to my coilovers. Would you guys get new OEM ones, or Energy Suspension ones?
TIA
-Heather
Old Oct 8, 2002 | 05:18 AM
Reid's Avatar
Global Moderator
Default Re: Upper Strut Mounts (acuracy389)
I'd get ITR upper shock mount bushings.
How did your coilovers cause those to get worn out though?
You might want to address the problem directly.
Old Oct 8, 2002 | 05:21 AM
acuracy389's Avatar
New User
Default Re: Upper Strut Mounts (Reid)
Well I am using B&G true coilovers. They were great to begin with, but now they make a lot of noise. My friend has the same setup on his Eclipse, and now his upper strut mounts are gone and so are mine. I don't know if this is directly related to the coilovers, but thats the only thing I can think that would cause this.
Old Oct 8, 2002 | 05:26 AM
Reid's Avatar
Global Moderator
As much as I'd hate to use solid pillowball mounts on a street car, you might want to consider going with those rather than continually replacing the bushings.
It's really odd that your coilovers are causing this to happen though.
Old Oct 8, 2002 | 05:39 AM
acuracy389's Avatar
New User
What else would cause this then??
Old Oct 8, 2002 | 05:40 AM
Reid's Avatar
Global Moderator
How do you know they're worn?
Got a pic?
Old Oct 8, 2002 | 05:42 AM
acuracy389's Avatar
New User
I can take a pic, but the noise they are making ( a loud clunking sound everytime my car hits a slight bump ) is the same noise my friends Eclipse makes.
Old Oct 8, 2002 | 05:50 AM
Reid's Avatar
Global Moderator
That loud clunking could be a number of things.
What leads you to believe it's the upper shock mount?
Old Oct 8, 2002 | 05:52 AM
acuracy389's Avatar
New User
Just my experience with my friends car... plus numerous people being in my car telling me that it is the upper strut mounts. I don't really know what to look for, but that noise is driving me insane.
Old Oct 8, 2002 | 05:54 AM
Reid's Avatar
Global Moderator
Just to get the obvious culprits out of the way,
your wheel/tyre combo isn't rubbing on anything is it?
EDIT: A "clunking" is usually related to a failed cv boot or a bad wheel bearing.
[Modified by Reid, 4:55 AM 10/8/2002]
acuracy389's Avatar
New User
No, not rubbing.
Old Oct 8, 2002 | 05:56 AM
Reid's Avatar
Global Moderator
Check the cv boots.
acuracy389's Avatar
New User
Umm... OK. Next question... how do I check them?
Old Oct 8, 2002 | 05:58 AM
Reid's Avatar
Global Moderator
Look at your cv boots on your axles and check for any damage.
Old Oct 8, 2002 | 06:03 AM
acuracy389's Avatar
New User
Thank you for your help
zoomhonda
May 13, 2010 02:07 PM
norurb
Feb 6, 2008 07:07 PM
t0ekn3e
Nov 5, 2004 02:41 PM
93EH6
Dec 13, 2003 03:36 PM
