is this type r?
Old Aug 3, 2004 | 10:42 AM
vtecpsyco's Avatar
Default is this type r?
i just got a 99 ex with a b16 swap,and ive noticed for a wile now that my throttle cable doesnt mount like the stock si cable mounts to the throttle body,so my friend told me that it was a gsr throttle body mounted to a b16 manifold,this wouldnt surprise me because this motor has some things changed around on it.(like ls tranny,which really sucks).but today i got a wild hair and decided to check it out and measure it,62 mm,and i checked many times.so im sure its 62 mm,that sounds kinda big for a gsr throttle body.can someone tell me if i have a type r throttle body please
Old Aug 3, 2004 | 10:56 AM
1Quikgsr's Avatar
search and no its not a type r -type r=65 which i believe.
Old Aug 3, 2004 | 10:58 AM
Bbasso's Avatar
Default Re: (1Quikgsr)
Yeah 65... bad guess.
Its 62mm.
Old Aug 3, 2004 | 11:01 AM
ZygSpeed's Avatar
Default Re: is this type r? (vtecpsyco)
Depends where you measured it ... at the flapper or just at the inlet to the manifold.
ITR is 64mm at the manifold down to 62mm at the actual throttle body/flapper.
Old Aug 3, 2004 | 11:02 AM
vtecpsyco's Avatar
Default Re: is this type r? (zygspeed)
then its not a type r,this one is 62 mm at where the intake bolts on ,so does that mean its a gsr
Old Aug 3, 2004 | 11:06 AM
ZygSpeed's Avatar
Maybe this will help out a bit:
http://autopedia.com/Acura/97_TypeRenginecut1.html
Not sure if it will actually help with your throttle cable mounting problem, though.
JeffBro
Jun 27, 2006 09:11 PM
JeffBro
Jun 26, 2006 05:58 PM
NightHawkC5
Feb 18, 2003 11:56 AM
whtgsr1998
Mar 6, 2002 08:08 PM
whtgsr1998
Mar 6, 2002 06:11 PM
