type e ecu?
Old Sep 29, 2004 | 08:12 PM
AFTERZERO's Avatar
Default type e ecu?
I tried doing a search, but was unable to find anything...anyways I recently got an ecu from a friend, he said its off a type r, but Im not sure it is. The code is p73 ao4 is this a type r ecu?
Old Sep 29, 2004 | 08:18 PM
jdm_cars's Avatar
Default Re: type e ecu? (crisparra)
yes, that code sounds correct,
but it sounds like a 00 or 01 ECU the A04 is the newer ones with the immobilizer if I am not mistaken.
if the Manufacturer is Keihin, it is 00 and 01 if is says Dairenken (something like that) it is the older one. Also you can tell by the size, if it is smaller, it is 00 or 01 if it is bigger, it is the older ones.
unless you got an 00 or 01 vehicle, the immoblilizer may give you problems.
Old Sep 29, 2004 | 08:25 PM
AFTERZERO's Avatar
Default Re: type e ecu? (jdm_cars)
its def a bigger ecu, the maker its denshigiken, well this one work on a 00 gsr with a type r swap?
OneTyteEK9
Apr 27, 2006 09:13 AM
hybrid racing
Feb 7, 2005 04:52 PM
OUTKAST_R
Feb 26, 2004 05:44 PM
