Traction bars?
Old Jan 12, 2008 | 04:36 PM
ZygSpeed's Avatar
Default Traction bars?
I get a pull to the right when I throttle it in 3rd on the highway.
GSR tranny w/Quaife, Mugen suspension bushing set w/Mugen engine mounts, cornerweighted prior to the cage install (potential issue), presently on PIC R3 suspension with something like maybe 1/8" total toe up front and 0 in the back.
Suggestions?
Old Jan 12, 2008 | 04:49 PM
Bradstard's Avatar
Default Re: Traction bars? (Zygspeed)
Turn down the boost?
Old Jan 12, 2008 | 04:54 PM
ZygSpeed's Avatar
Default Re: Traction bars? (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Turn down the boost?</TD></TR></TABLE>
Not an answer I was looking for, since it's only 15 psi and there's no adjustable boost controller (by design).
Motons go on 1/30 at Piper's with adj. front upper arms (Skunk 2 Pro +).
I'll have them look for loose stuff at that time when the alignment and cornerweighting is re-done.
Old Jan 12, 2008 | 04:56 PM
JjuuN R's Avatar
LOL Brad.
I think it's worth a shot Ed, those mated with the Mugen engine mounts will be unbelievably solid.
I say get your car re-corner weighted first, make sure the alignment is perfect, if you still get a pull to the right then go for it. IMO they're good to have anyway.
Old Jan 12, 2008 | 05:03 PM
ZygSpeed's Avatar
Default Re: Traction bars? (JjuuN R)
I've got some oil cooler lines running along the radiator support as well as a remote oil filter right up there, so it looks like a little re-do for the "bars" after the suspension install.
Oh well, I'll be done spending money on it shortly ... and finally start driving it a bit soon.
Old Jan 12, 2008 | 05:09 PM
JjuuN R's Avatar
I wish I could say I was done spending money on it shortly. I don't care though, it's fun to me, and have lots of crazy ideas...
Old Jan 12, 2008 | 05:13 PM
ZygSpeed's Avatar
I didn't say I'd be finished paying for it, just that the build should be finished soon (after the splitter and brake ducting), for the time being.
Old Jan 12, 2008 | 05:52 PM
RStoR's Avatar
Ed - Not sure if it's the case with the DC2 version, but on my Full Race traction bar set-up the radiator support bar hangs lower than the actual support. This could present a present a problem when trying to fit a splitter. Not the best picture but gives you and idea. I can get you a front view of the car is you want to see it better.
Old Jan 12, 2008 | 05:58 PM
ZygSpeed's Avatar
Default Re: Traction bars? (RStoR)
Thanks for the pics.
Splitter et al. will be a bit lower than those things, though the other night I was thinking of how much actual clearance I should build into the gap between it and the pavement.
I'll deal with that stuff after the suspension install.
One thing at a time ...
Old Jan 13, 2008 | 03:29 AM
Bbasso's Avatar
http://www.cardomain.com/ride/503605/3
Old Jan 13, 2008 | 04:03 AM
Doostur's Avatar
You need more boost to even everything out
Old Jan 13, 2008 | 04:16 AM
Thrizzle's Avatar
* B A N N E D *
Default Re: (Doostur)
After getting a traction bar you won't drive with out one!
Night and day difference on my car.
Old Jan 13, 2008 | 04:22 AM
Doostur's Avatar
Too bad L-Con stopping make their traction bars
Old Jan 13, 2008 | 04:44 AM
migs's Avatar
What type of sway bar do have upfront? If it is stock ITR, I would suggest upgrading from that. Ed, can you post your alignment specifications inluding camber and caster?
Old Jan 13, 2008 | 07:28 AM
ZygSpeed's Avatar
Default Re: (migs)
Mugen front, 32mm ASR rear, Mugen suspension bushings, 1/8" total toe out, 0 toe in the rear.
Now that I'm typing this out I do recall that the right side front camber was probably + 0.7 degrees and the left at - 0.7 degrees. This was the best the shop could do for the alignment after the cornerweighting.
So, as mentioned above, I've got some front camber adjustment that will be installed along with the new shocks, F & R bearings, and ARP studs.
summary ... I'm pretty sure the present camber issues aren't helping any, but that a nice set of tractin bars would help keep the front in tack under load.
Old Jan 13, 2008 | 07:31 AM
GO-FIGHT-KILL's Avatar
It's torque steer.
You have a boosted B-Series, it comes with the territory... Then again, I'm not entirely clear on what kind of pulling it is, so it might be an alignment/suspension problem.
But 15psi on a B-Series, with a decent sized turbo (As I remember you having), will cause torque steer regardless... Unless you somehow engineered equal length axles.
Old Jan 13, 2008 | 07:40 AM
ZygSpeed's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">But 15psi on a B-Series, with a decent sized turbo (As I remember you having), will cause torque steer regardless... Unless you somehow engineered equal length axles. </TD></TR></TABLE>
Yes, I understand.
Note that I was trying to see what the motor would do in 3rd on the highway at about 55 mph (~4000 rpm), with a full stomp on the throttle, since at that same vehicle speed in 5th I'm only doing ~2500 rpm and only get ~2.5 psi (yeah, the turbo is sized for the top end of the rev range).
I think some of it is probably the uneven camber up front (soon to be remedied), and traction bars couldn't hurt ...
Modified by Zygspeed at 11:51 AM 1/13/2008
Old Jan 13, 2008 | 10:34 AM
KOALA YUMMIES's Avatar
Default Re: (Zygspeed)
I remember some old threads in the Road Racing/Auto-x forum discussing the use of traction bars on a road course, and the end result being that you wouldnt want to have them on a track car, but then again I could be wrong. This is if you still intend on tracking the car. IMO I would never buy/use any brand of traction bars.
Heres some threads on it:
https://honda-tech.com/zerothread?id=940859
https://honda-tech.com/zerothread?id=1202148
Old Jan 13, 2008 | 10:38 AM
ZygSpeed's Avatar
Default Re: (KOALA YUMMIES)
I'll look at the links, but both Jack (B18Cxr) and Don (turbo civic, mrlegoman) seem to have had good results with them, as has Rob Basso.
Old Jan 14, 2008 | 01:33 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">I remember some old threads in the Road Racing/Auto-x forum discussing the use of traction bars on a road course, and the end result being that you wouldnt want to have them on a track car, but then again I could be wrong. This is if you still intend on tracking the car. IMO I would never buy/use any brand of traction bars.
https://honda-tech.com/zerothread?id=1202148</TD></TR></TABLE>
I honestly could care less what's in those threads, even if I posted in them.
For many years I have the Z10 traction bars with plenty of track & street miles and not one single bad thing to say. But I do have many good things to say.
HT, not always filled with good info. Don't always believe what you read here.
Old Jan 14, 2008 | 07:47 AM
RTW DC2R's Avatar
I use traction bars on my R and had them on at VIR.
Old Jan 14, 2008 | 12:36 PM
citrus3000psi's Avatar
Default Re: (KOALA YUMMIES) (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
Would like to hear more. I've read through threads of using that with road racing as a negative. Are you saying there neutral or positive. I have no desire to do straight line dragging aka dropping the clutch. But if these are benefical at the track I would consider them.
Old Jan 14, 2008 | 01:20 PM
RStoR's Avatar
Default Re: (KOALA YUMMIES) (citrus3000psi)
Read this http://www.full-race.com/artic...s.pdf
Old Jan 14, 2008 | 01:40 PM
DontBlink's Avatar
Default Re: (KOALA YUMMIES) (RStoR)
I been useing the Z10 bars on my car for many years.
they help with the wheel hop issues but i mostly felt them in the turns with a more solid feel in the front end.
The only bad part of my Z10's is the way they are pulling on the lower control arm bushings where they attach on the lower control arm, mine are split pretty good, but thats also due to several years off stresses im sure.
But read from the full race site about there attachment points compared to other bars.i personally never had or felt any binding issues but i like full races attachment point on solid bolts rather than on a rubber bushing.
Of all the traction aiding products out there, nothing beats a good set of sticky tires.
Old Jan 14, 2008 | 07:27 PM
B18CXr's Avatar
Ed-
Set the bars up so that the heim's are "floating" in the socket, then make sure the caster settings are "in spec".
Pre-loading the arms (either fore or aft) will yield different results.
You will not believe the difference, a must mod for RR guys.
P.S. Full Race bar below....
Berman
Jan 31, 2008 11:47 PM
eyesolation
May 3, 2006 04:46 AM
holisticbeatz
23
Jan 11, 2006 08:06 PM
ScratchAddicts
Jun 26, 2005 03:58 AM
xlr8
Jun 28, 2004 04:21 AM
