Torque Specs.
Old May 24, 2002 | 06:06 PM
RaVAGE00's Avatar
New User
Default Torque Specs.
Just looking for the Torque spec's for the upper and lower tranny plugs? 2001 ITR.
O, before I forget, Should I just stick with Honda MTF or should I try some of the more exotic stuff?
Thanks
Old May 24, 2002 | 06:09 PM
B2FiNiTY's Avatar
Default Re: Torque Specs. (RaVAGE00)
I would stick with Honda MTF.
Old May 24, 2002 | 06:47 PM
IN VTEC's Avatar
Don't worry about the specs. Just make sure they're tight enough so they don't come loose. The MTF on the threads will probably screw up the amount of torque anyways.
Old May 24, 2002 | 07:25 PM
JSIR's Avatar
New User
33 ft/lbs on the filler plug and 29 ft/lbs on the drain plug, I wouldn't worry about it though, just snug them down tightly, its kind of hard to get a torque wrench in there unless you are on a hoist. Honda MTL is great stuff, wouldn't use anything else myself.
Joey
[Modified by JSIR, 8:26 PM 5/24/2002]
SOHCEK-Turbo
39
Jan 6, 2020 09:44 AM
EG-SIXV-TEC
Honda Civic (2001 - 2005)
Apr 7, 2009 07:32 PM
smxcan
Jan 12, 2009 07:17 PM
