TodaSi blows....
Old Jun 23, 2003 | 03:54 PM
TodaSi's Avatar
Default TodaSi blows....
I was at the ClubSi event at Gingerman Raceway in South Haven, MI.
Running a strong lap, car pulling hard during my group's second lapping session of the day, hard on the brakes into turn 11 then on to the front straight, 3rd gear, 4th gear, suddenly the power feels flat "?" then BAM!!!! threw #2 rod through the block
No knocks, now rattles, no pinging, just an instant of flat power and BAM game over.
B18c5 block
blue printed balanced
knife-edged crank
ITR rods
Toda pistons
Spec C cams
Good thing is I only lost about 1/2 quart of oil Gained a new big hole in block though
Now what to do? B18c1, B16a, B20?
Still don't have a clue why it happened.....
Old Jun 23, 2003 | 03:57 PM
Drag R's Avatar
Default Re: TodaSi blows.... (TodaSi)
how many miles were on the motor? Im sure u had a good run.
nick
Old Jun 23, 2003 | 03:58 PM
TodaSi's Avatar
Default Re: TodaSi blows.... (Drag R)
About 20,000, maybe a little more
Old Jun 23, 2003 | 04:00 PM
yoshi234's Avatar
I shoot brides
aw mang, soly to hear chad
Old Jun 23, 2003 | 04:15 PM
acydphryck's Avatar
JESSSSSSSSAAAAASSSSSSS!!!!!!! WOW!!!! well, time to go to bigger better things...like a GSR motor or something...hope things work out for the best man. that was a strong running motor...
Old Jun 23, 2003 | 04:21 PM
ITR764's Avatar
Default Re: TodaSi blows.... (acydphryck)
sucks a fat one!!!
Old Jun 23, 2003 | 04:22 PM
zijiejijeijrkjk's Avatar
Default Re: TodaSi blows.... (ITR764)
Ah man, that did suck. Seems to have been a bad day @ gingerman for a few.
Old Jun 23, 2003 | 04:23 PM
00MRSi's Avatar
Oh man, sorry to hear this Chad.. Does a "knife-edged" crank lose its strength compared to a regular one?
Old Jun 23, 2003 | 04:24 PM
Big Phat R's Avatar
Dayum! That's my worst nightmare - grenading the motor with no warning.
Do you have a baffled oil pan?? Did you check the oil before that last session? Have you ever over-revved the engine before??
Maybe you had an injector fail on you? What kind of injectors are you running?
For the new motor - I say B20 VTEC or B18 sleeved to 84.5mm
Old Jun 23, 2003 | 04:28 PM
TodaSi's Avatar
Default Re: TodaSi blows.... (scott_k)
Yes, Ausmith's 1998 Integra Type R #55 was totaled. I believe his father put a wheel off in turn #6, got sideways and then shot off the track into a berm. Wai was in the car as a passenger. Both were alright, don't think the car will make it though Whole front end is pushed over to the side and down.
I think he made out much worse than I did
Old Jun 23, 2003 | 04:32 PM
TodaSi's Avatar
Yes, oil was fine, check each session
Run 440cc injectors
Not baffled pan....a thought but would expect 1 or 4 to go before #2 if it was oil starvation.
Just ran out there 11 days prior, no problems.
B20? gonna have to think about that, never really considered a b20. Can those rev to 9000 easy?
Old Jun 23, 2003 | 04:35 PM
ITR764's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote"> Whole front end is pushed over to the side and down.
that sucks an even fatter one!!!!!!!!!
Old Jun 23, 2003 | 04:38 PM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">Can those rev to 9000 easy?</TD></TR></TABLE>
With forged internals and a fully balanced rotating assembly - why not? you already have the pistons - just get new forged rods. Is your crank ok?
Old Jun 23, 2003 | 04:42 PM
TodaSi's Avatar
Default Re: TodaSi blows.... (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
With forged internals and a fully balanced rotating assembly - why not? you already have the pistons - just get new forged rods. Is your crank ok?</TD></TR></TABLE>
Well, just looking through the BIG *** HOLE with a flashlight, it doesn't look too bad. There are a couple of nicks on it, but it may work. Gonna let it set for a few days until I get over being mad at it. Bad motor, bad.
Old Jun 23, 2003 | 05:31 PM
TodaSi's Avatar
Couple of quick pics
Old Jun 23, 2003 | 05:34 PM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">Yes, Ausmith's 1998 Integra Type R #55 was totaled. I believe his father put a wheel off in turn #6, got sideways and then shot off the track into a berm. Wai was in the car as a passenger. Both were alright, don't think the car will make it though Whole front end is pushed over to the side and down.
Noooo. That sucks. Glad the driver/passenger sound ok though.
Can't offer you any ideas on the build. Although I will say a built B20 would definitely make you happy. Torque owns.
Old Jun 23, 2003 | 06:21 PM
Dave-ROR's Avatar
I think he made out much worse than I did </TD></TR></TABLE>
Sorry to hear about your motor Chad, but even more sorry to hear about a totalled car. Damn.
Have a few 's to recover.
Old Jun 23, 2003 | 06:44 PM
Michael Delaney's Avatar
? ITR rod bolt failure
? stock oil pump gear
? stock unbaffled oil pan
? fuel pump
? RC injector failure
Old Jun 23, 2003 | 06:46 PM
defcon1Racing's Avatar
another pic:
Bummer. I'm sure whatever you build next will be even better Chad. Just like Steve Austin, no?
Old Jun 23, 2003 | 06:47 PM
TodaSi's Avatar
Default Re: TodaSi blows.... (Michael Delaney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Delaney &raquo;</TD></TR><TR><TD CLASS="quote">? ITR rod bolt failure
? stock unbaffled oil pan</TD></TR></TABLE>
Yep, pick one
Old Jun 23, 2003 | 06:49 PM
spoonek4's Avatar
Probably the OEM rods I guess.
Old Jun 23, 2003 | 06:51 PM
Charlie Moua's Avatar
damn that's hella sad bro. You have one of the best NA setup here...
makes me wanna cry for you ....
But you'll get over it quick.
chew on this
b18c5
rebuilt
jun/TODA 2.0 stroker kit
keep your same head.
sell the jun pistons or toda pistons
have fun.
have one on me
Old Jun 23, 2003 | 06:53 PM
Kengs's Avatar
Default Re: TodaSi blows.... (spoonek4)
Ohhhhh no...
Old Jun 23, 2003 | 06:55 PM
TodaSi's Avatar
Default Re: TodaSi blows.... (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Ohhhhh no... </TD></TR></TABLE>
Yea, I need a case of that JDM coffee That'll perk me up. Get it perk
Old Jun 23, 2003 | 07:11 PM
jonas's Avatar
holy ****, sorry to hear Chad.
tear it up with the new set up
