tips on swapping an ignitor
Old Jan 16, 2003 | 11:39 AM
andrewasf77's Avatar
Default tips on swapping an ignitor
hey guys. thanks to len, my oem ignitor came in today and i was wondering if you guys could give me any tips that might make the job a little easier. anything you can contribute would be helpful and so would any pics. thanks
andy
Old Jan 16, 2003 | 12:07 PM
vtec.dc2's Avatar
Default Re: tips on swapping an ignitor (andrewasf77)
well.. i replaced the rotor, ignitor should be right behind there... take the cap off, then remove the rotor (that part might not happen as easy), then theres a leak cover and ignitor should be right behind it, attached by 2 screws from the top and 2 wires on the side..
[Modified by vtec.dc2, 4:14 PM 1/16/2003]
Old Jan 16, 2003 | 12:12 PM
Default Re: tips on swapping an ignitor (vtec.dc2)
yea i did my cap and rotor a little while ago and that was cake
Old Jan 16, 2003 | 12:40 PM
magic hat #9's Avatar
yep, remove cap/rotor, the plastic shield (pops right out), and then 2 screws on top of the ignitor and it's out.
Old Jan 16, 2003 | 12:41 PM
Default Re: tips on swapping an ignitor (magic hat #9)
word
Old Jan 16, 2003 | 12:44 PM
thanks guys, anyone else feel free to post any helpful tips
Old Jan 16, 2003 | 12:57 PM
Doctor CorteZ's Avatar
needle nose visegrips for when the heads round off the screws.
it happens to me most of the time and these are the best thing I've found to break them loose.
Old Jan 16, 2003 | 01:00 PM
sgT's Avatar
sgT
I hope you know the screws for the ignitor are on the OUTSIDE of the distributor.
This magic hat fellow is confusing the ignitor with the COIL.
Old Jan 16, 2003 | 04:55 PM
B18EG6's Avatar
Default Re: tips on swapping an ignitor (sgT)
dont got a type r, but on my gsr motor...i took the dist out of the car, it was loads easier
Old Jan 17, 2003 | 06:05 AM
Default Re: tips on swapping an ignitor (B18EG6)
im about to start the job now, any last minute thoughts?
Old Jan 17, 2003 | 10:00 AM
typer_801's Avatar
In the picture above, is the piece opposite the ignitor (shaped like California) part of the distributor or something seperate? It's damaged on my car and needs replaced. TIA.
Old Jan 17, 2003 | 10:29 AM
sgT's Avatar
sgT
Default Re: tips on swapping an ignitor (typer_801)
TDC and or CYP sensors. if its damaged, you need to replace
lmike6453
Feb 22, 2008 07:34 PM
reymond23
Nov 23, 2007 11:06 PM
mormonboy
May 2, 2007 02:32 PM
hotdoggies
Jan 27, 2006 12:08 AM
vuthe32
Sep 7, 2003 02:22 PM
