Timing question ?????
Old Jul 7, 2002 | 05:30 PM
Euro98ITR's Avatar
Default Timing question ?????
Will advancing the ignition timing improve performance on my ITR evrything stock except an AEM CAI and no cat! ?? I heard that some make it 18 deg. is this correct? Are there any side effects doing this?
'98 Eurospec ITR with 4k on the clock! AEM CAI , no cat. , and APEXI N1 cat-back comming soon!
Old Jul 7, 2002 | 05:49 PM
FSTASNTZ's Avatar
Default Re: Timing question ????? (SF-ITR)
It can. I personally ran mine at 18 degrees of base timing with those mods. It responded just fine. Other ITRs I helped tune liked almost 19 degrees.
18, I would think, would be safe...
Jason
Old Jul 7, 2002 | 07:37 PM
t's Avatar
t
Default Re: Timing question ????? (FSTASNTZ)
Stock spec. is 14-18 degrees, so you will still be in stock spec.
Old Jul 7, 2002 | 07:52 PM
Driver's Avatar
Default Re: Timing question ????? (t)
just advance it to the max it can go !!!
Old Jul 7, 2002 | 07:55 PM
ShyGuy's Avatar
Default Re: Timing question ????? (01-1214)
What exactly does advancing the timing do? and how does it result in more performance?
Old Jul 7, 2002 | 08:12 PM
Bob#455's Avatar
Default Re: Timing question ????? (ShyGuy)
Advancing the timing to 18 degrees will yield a couple whp across the RPM range, but the best result is improved throttle response.
integraboy22
Jul 26, 2007 06:16 PM
integraboy22
Jul 26, 2007 03:42 PM
ranta18
Sep 21, 2004 09:39 AM
Ideal R
Jun 28, 2001 09:22 AM
