Tech Help Needed: Hatchback latch
Old Aug 14, 2006 | 12:08 PM
RStoR's Avatar
Default Tech Help Needed: Hatchback latch
Looking for any insight before I begin tackling this. A search didn't return anything.
Hatchback unlocks as it should, audible. When latch handle is used to open, the hatch will not open. If the key is inserted, turned to the open position, and held then the hatch opens.
Obviously it sounds like a latch-mechanism problem. Anyone had this problem?
Old Aug 14, 2006 | 12:19 PM
PrinceAli132's Avatar
Default Re: Tech Help Needed: Hatchback latch (RStoR)
This might help;
http://www.team-integra.net/se...=1117
Ali
Old Aug 14, 2006 | 12:36 PM
cmdr430's Avatar
i had that problem......
i just took it to my friendly neighborhood Acura technician and had it warrantied .......
Old Aug 15, 2006 | 03:41 AM
BudMan's Avatar
Default Re: Tech Help Needed: Hatchback latch (cmdr430)
common problem. Replace the latch mechanism. I replaced mine 6 months before I took it out to build the race car.
$50 shipped. (It was $74 from acura)
Old Aug 15, 2006 | 04:10 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">i had that problem......
i just took it to my friendly neighborhood Acura technician and had it warrantied .......</TD></TR></TABLE>
My next new car will have the most extended warranty available!
Old Aug 15, 2006 | 09:52 AM
floatfisher's Avatar
mine is still being fixed by the dealer under warranty. So far they ordered a new latch and they also had to order the acuator (i might be wrong on the name and part for that one). The last part hasnt come in yet but it should be completely fixed by wed or thurs. By then I can tell you for sure what parts I needed from the invoice
Old Aug 15, 2006 | 10:11 AM
BLacK FirE's Avatar
Default Re: (floatfisher)
same thing happened to mine last month. Haven't gotten around to trying to fix it yet though.
Old Aug 18, 2006 | 11:32 PM
well, i got the latch fixed at the delaer b/c it was covered under warranty still. I needed:
1 74800-st7-ao2 (lock assy, tail GA
2 91505-sl0-003 (clip, cowltop)
1 74840-st7-ao1 (actuator assy, T/G
hope this helps
Old Aug 19, 2006 | 11:13 AM
T3k C's Avatar
That's funny, mine just started doing that here and there.
khmerboiracer
Aug 2, 2007 10:00 PM
Slammin585
May 24, 2006 09:54 PM
metal-x
Mar 6, 2005 04:49 PM
Sergei01
Feb 2, 2004 08:06 PM
tizz
May 22, 2003 12:05 PM
