Tech Help: Catback Install
Old Sep 12, 2002 | 11:20 PM
Stock R's Avatar
Default Tech Help: Catback Install
Hey guys. I'm picking up a used apex n1 catback tomorrow for the R.
I was wondering what I need for the install. I have 4 car stands, 1 jack, 1 torque wrench, 12mm socket, a catback system, the R and a buddy.
Is that pretty much all i need? Do i need stuff like new gaskets or hangers (2001 itr with 7000kms)?
Thanks a lot.
BTW, how high do I roughly need to jack up the car? I have a feeling I won't be able to get it high enough. Any ways to boost it up?
Old Sep 12, 2002 | 11:25 PM
disordeR's Avatar
Default Re: Tech Help: Catback Install (Stock R)
12" to 18" is good. you might need a 13mm-16mm just in case. i forget if i used those. new gaskets are always good. i hope you are getting hardware with that catback as well. easy install, good luck.
Old Sep 12, 2002 | 11:30 PM
SamC's Avatar
Default Re: Tech Help: Catback Install (disordeR)
also a breaker bar... and also w40 to get the rubber hangers off
Good Luck!
Old Sep 13, 2002 | 12:55 AM
zer0zer0 TypeR's Avatar
Default Re: Tech Help: Catback Install (SamC)
the 3 bolts from the b pipe to the cat are a B!TCH. the top bolt is damn nearly impossible even with a torque wrench. make sure you have alotta lube and a long extension for your wrench. other than that it's simple. good luck.
Old Sep 13, 2002 | 01:39 AM
uNF$@#!'s Avatar
Default Re: Tech Help: Catback Install ('00TypeR)
hangers need wd40 like mentioned, fairly easy if you let it soak a bit. the cat if you never took off the cat before, you will see lots of rust. i dont even thinkg you will have clearance to get the leverage to use a breakerbar properly.
a lift would make it much easier
edit: also wear glasses or goggles if you dont want crap to fall into your eyes
[Modified by Soup ****, 5:39 AM 9/13/2002]
Old Sep 13, 2002 | 04:33 AM
Asahi's Avatar
You best bet for the bolts on the cat are stop by a shop and sweet talk a mechanic into hitting them with an air gun. break them loose and hand tighten them back.
The top bolt of the 3 is a bitch to get off regardless
Old Sep 13, 2002 | 06:35 AM
01ITR#700's Avatar
Default Re: Tech Help: Catback Install (Asahi)
Agreed, go to a shop and have them bust those three bolts behind the cat off w/ an air gun, I've spent tons of time on my back trying to break those loose with no leverage, it's no fun to say the least...
M
Old Sep 13, 2002 | 06:38 AM
Hooch'n's Avatar
Default Re: Tech Help: Catback Install (01ITR#700)
Not much to it! The worst part is braking the old bolds off.......
Old Sep 13, 2002 | 09:46 PM
Stock R's Avatar
Default Re: Tech Help: Catback Install (Hooch at 8400-RPM)
Thanks for the advice everyone.
but it's all wasted now.
I went straight from the bus terminal (went hom from uni) to meet the guy at 12:30 in the morning. Waited 1 hour. Called him 3 times. No reply.
I get home to find an email saying that he sold it to someone else.
Damn bastard.
Don't buy from DC8888 or spoon3168@hotmail.com
Old Sep 13, 2002 | 09:49 PM
sackdz's Avatar
what an assclown.
[Modified by sackdz, 1:50 AM 9/14/2002]
Old Sep 14, 2002 | 06:25 AM
snake01's Avatar
Default Re: Tech Help: Catback Install (sackdz)
it's a pretty hart pounding process you'll make it thow.
good luck
OJ Glove
Honda Civic (2006 - 2015)
10
Jun 1, 2007 06:17 AM
Conartist329
Jul 19, 2005 09:58 PM
98civic1129
Feb 13, 2004 04:39 PM
Mikes94
Mar 20, 2002 05:07 AM
Mikes94
Mar 20, 2002 05:01 AM
