Suspension Setup
Old Sep 22, 2001 | 03:28 PM
Cyrio's Avatar
Default Suspension Setup
Has anyone tried Ground Control coilovers with KYB AGX shocks on their R? I want to lower the car but not ruin the handling or ride feel of the car? Will this setup work for what I want?
Old Sep 22, 2001 | 05:43 PM
jimbob's Avatar
New User
Default Re: Suspension Setup (Cyrio)
Why would you even think of putting KYB AGX shocks on an ITR? The stock Showas are so much better. I don't believe you can lower the car without ruining the handling or feel of the car without VERY VERY careful suspension tuning. The ITR came VERY well balanced and tuned. If you want to change suspension, you'll have to go with something pretty good to improve upon it...
Old Sep 22, 2001 | 06:07 PM
Jesse H's Avatar
Default Re: Suspension Setup (jimbob)
KYB doesn't make rear shocks for the R, nor did they make any for my 88 CRX (similar rear LCA type).
Old Sep 22, 2001 | 06:28 PM
yellow blur's Avatar
Default Re: Suspension Setup (Jesse H)
i think the bilstein specific R shocks and ground control setup is very good. this is personally what i want, if i don't shell out 1000 bucks for some j-spec coilovers first.
big phat r, is running this setup with custom ERS, eibach race springs, and he really likes it. hth.
yb-b0t: who took off his rear windshield wiper today
Old Sep 22, 2001 | 06:31 PM
Cyrio's Avatar
Default Re: Suspension Setup (yellow blur)
Where can i find some info on bilstein specific R shocks?
Old Sep 22, 2001 | 06:49 PM
Cyrio's Avatar
I did a little research on these Bilstein shocks and it seems like a lot of people are using them and like them. So how would Ground Control coilovers with Bilstein ITR specific shocks sound? Would this setup work well for me?
Old Sep 22, 2001 | 07:07 PM
go for it chris!
that way i can see if i like them haha, im pretty sure itll be a great setup, and you can customize spring rates from groundcontrol.
Old Sep 22, 2001 | 07:20 PM
mugenr#1011's Avatar
dont screw it up dude..im sure you wont do alot of research....im sure you've done that to....good luck.....mugen
Old Sep 22, 2001 | 07:41 PM
mafay2's Avatar
New User
Default Re: Suspension Setup (mugenr#1011)
If you don't have the $$ for real coilover, I would just get the TEIN NA and be happy ever after!
Unless you can go corner weight your car and you really take you car to race, you don't really need a coilover. I have the NA and put it to the highest C ring setting, and it lower around 1.2-1.5" both front and back, look really nice!
The ride quality is very good too, soft and comfortable on the street, but it will stiff up during corner!! And the softest setting on the shock is just like stock and when you on the stiffest setting, it is very stiff!!
Old Sep 23, 2001 | 10:00 AM
ZygSpeed's Avatar
I've cot the Bilstein/GC combo, and I think you'll be better off with the Mugen low-down kit and their rear bar (seriously).
The Bilsteins are NOT adjuster dampers, and you'll have to do some guessing for spring rates (nobody seems to run the same springs). Whereas, the Mugen shocks are made to lower the car about .75 inch, they are adjustable dampers, the rear bar will help with the rear (help eliminate understeer) and it's all plug and play.
BTW -- your car looks good with the new front end (saw your post a while back), and tell your dad I said "hello". /Ed Pipala
Old Sep 23, 2001 | 12:02 PM
Cyrio's Avatar
Default Re: Suspension Setup (zygspeed)
Ed: What about the setup you have now don't you like? I know the Mugen setup is better, but also more expensive.
Old Sep 23, 2001 | 12:31 PM
R1020's Avatar
ed, have you cut your bumptstops yet?
i'm running a GC/koni yellow setup (running the '88 crx rears). the konis are adjustable, and MUCH better than KYB's.
i like my setup, and think that the GC's are pretty underrated (flames welcome...). but i want to try the r-specific bilsteins, just to see what they feel like with the GC's.
my $0.02.
Old Sep 23, 2001 | 12:38 PM
Default Re: Suspension Setup (R1020)
chris, i dont have any setup right now, its just stock. thing is, i want the gc/bilstein combo. when i had my eibach springs on stock shocks, it freakin sucked. thats my only experience with suspension so...
pete, yeah, i had to cut the bumpstops when i installed the eibach springs, so they're cut right now on the stock sus.
Old Sep 23, 2001 | 12:41 PM
R1020's Avatar
ed, sorry, when i said 'ed' in the previous post i mean zygspeed . . . whoops!
Old Sep 23, 2001 | 12:46 PM
haha, ed is the bomb diggity name
Old Sep 23, 2001 | 12:49 PM
jond's Avatar
If I were going to mess with the suspension(which I never would), I would copy realtimes setup. Not sure if its lower, but they use eiback springs and mugen double-adjustable shocks
Old Sep 24, 2001 | 05:34 AM
ZygSpeed's Avatar
Chris, I'm just spoiled. I like nice cars and drive them the way .... well, you know.
Suspen set-ups tend to be personal choices, eventually a trade-off between comfort and performance.
I'm sure the Bilstein/GC combo would be fine for the average Joe for a daily driver, but it's a stop-gap compromise IMO.
There's no damping adjustment (which I believe the low-downs have), there's no shock-integrated upper spring support (since the GC sleeve and perch only provide a lower spring seat), and there's still the spring choice issue. Not to mention that the shocks and sleeve kit will already run you about $950-1k anyway!! Spend the extra 4-500 on the good ****, and maybe get the Mugen USTBs as well.
If you just want to lower the car in the mean time I'll send you my Eibach (sportline?, were supposed to be H&R) springs for the cost of shipping (I'm trying to get rid of as much stuff that's just lying around as possible, lately).
Keep it shiny side up. /ed
P.S. - Frankly, I liked those springs and didn't mean to change them (stock bump-stops), but my mechanic said he was having some difficulty installing them with the Bilsteins, so I ended up with the GC sleeve kit!!
Yellow Blur -- If you still want a Bilstein/GC combo then make me an offer, I've got 2 sets of spare springs as well (and then I'll get a low-down set up, too).
[Modified by zygspeed, 9:39 AM 9/24/2001]
jonnybadboi9
Suspension & Brakes
Sep 8, 2008 08:31 PM
JTN416
Jul 25, 2008 09:57 AM
TigerLy
Jun 17, 2008 01:07 AM
Sh4rky
May 8, 2003 02:08 AM
