Starting Issues....
Old May 28, 2003 | 06:22 AM
RaVAGE00's Avatar
New User
Default Starting Issues....
Question... wondering if other R owners are have issues when starting the car... It seems most times I try to fire the engine up, it starts very quickly, however, sometimes, I have to turn the key awhile longer... seems odd to me...
Old May 28, 2003 | 06:24 AM
vtec.dc2's Avatar
Default Re: Starting Issues.... (RaVAGE00)
when you place the key in ignition, do you crank right away? or wait for a second or 2?
Old May 28, 2003 | 06:25 AM
RaVAGE00's Avatar
New User
Default Re: Starting Issues.... (vtec.dc2)
I crank it right away.... put the key in and turn...
By the way, the car is maintained well... I replace the plugs every year... the wires are stock...
Old May 28, 2003 | 06:34 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">I crank it right away.... put the key in and turn...
By the way, the car is maintained well... I replace the plugs every year... the wires are stock...</TD></TR></TABLE>
slow it down a little, you probably don't need to wait more than a second with stock setup. place the key in ignition, turn it, wait 1-2 seconds and crank it.. i can't remember how it worked with stock setup - cause it wasn't much of an issue, but with my current setup i wait for check engine light to disappear after i turned the key all the way and then crank it.. or turn the key all they way, wait for the buzzing noise from fuel pump or lines to stop, then crank it
Old May 28, 2003 | 06:36 AM
RaVAGE00's Avatar
New User
ok. I will try that. so put key in... wait 2 seconds and fire her up
Old May 28, 2003 | 06:39 AM
vtec.dc2's Avatar
something like that, maybe less time.. just look for the engine light to disappear then crank.. or listen for fuel pump or lines noise to stop and then crank it..
Old May 28, 2003 | 06:55 AM
RTW DC2R's Avatar
I wait until either the check engine light goes off, or I hear the fuel pump finish its start up process. I do this with any car, force of habit.
Old May 28, 2003 | 06:56 AM
01-1293's Avatar
some times if i turn my car off........go into somewhere to grab soemthig and come out say a minute later....it takes longer to start and sputters a bit at first......its been liek that since day 1
Old May 28, 2003 | 07:01 AM
RaVAGE00's Avatar
New User
Default Re: Starting Issues.... (01-1293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 &raquo;</TD></TR><TR><TD CLASS="quote">some times if i turn my car off........go into somewhere to grab soemthig and come out say a minute later....it takes longer to start and sputters a bit at first......its been liek that since day 1</TD></TR></TABLE>
EXACTLY... what mine does... and it also has been doing this from day one... I think they are all like this.
TypeR 01 886's Avatar
Yes... its nothing to worry about. Its completly random. Sometimes you have gas still in your cylendar and it sparks up quick... or you need a little more and it takes a little longer. Its just how engines work
Old May 28, 2003 | 07:14 AM
RaVAGE00's Avatar
New User
Default Re: Starting Issues.... (TypeR 01 886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">Yes... its nothing to worry about. Its completly random. Sometimes you have gas still in your cylendar and it sparks up quick... or you need a little more and it takes a little longer. Its just how engines work </TD></TR></TABLE>
hmmm intresting... well, I think it may be a B series issue maybe... my 2 volkswagen Golfs never had that issue... but then again... totaly different car.
Thanks!
Old May 28, 2003 | 07:16 AM
vtec.dc2's Avatar
this is not random in my case.. once i started doing what i mentioned earlier, - i never had that problem..
Old May 28, 2003 | 07:22 AM
RaVAGE00's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">this is not random in my case.. once i started doing what i mentioned earlier, - i never had that problem..</TD></TR></TABLE>
giddy up... hey since we are on the issue of starting related issues... what is the purpose of units like MSD? Better spark, therefore, better performance, etc, etc, etc,
Also, how oftern do you guys replace your fuel filters.
Old May 28, 2003 | 07:52 AM
oz#227's Avatar
New User
Unless you have extensive mods. You don't need to Upgrade the ignition system.
But Yes, MSD etc... Bigger spark..blah blah.
I change all my filters and oil every 10,000 Kms ( 6213 miles ).
Old May 28, 2003 | 07:54 AM
RTW DC2R's Avatar
Also, how oftern do you guys replace your fuel filters.</TD></TR></TABLE>
I think the manual says 60,000miles for fuel filters. I think I changed mine at 30K though just to keep things fresh.
b18b1ef8
Apr 26, 2008 03:59 PM
ekcivic9
May 29, 2006 08:16 PM
LSracing94
Nov 25, 2005 10:23 PM
RockLee`
Sep 18, 2005 06:30 PM
gwakie
Feb 10, 2005 05:12 AM
