Starter ?
Old Nov 21, 2002 | 04:18 PM
96BlackHB's Avatar
Default Starter ?
I did a search and couldn't get an answer . Can I use any b series starter on a JDM itr 96 spec tranny or will I need a JDM itr starter? I plan on using a toda flywheel if you think that makes a difference. Thanks.
Old Nov 21, 2002 | 06:18 PM
FULLTHROTTLE's Avatar
Default Re: Starter ? (96BlackHB)
any B series will work. all starters for Manual trannies from any B series will work.
the bolt pattern never changed.
Old Nov 22, 2002 | 03:50 AM
96BlackHB's Avatar
Default Re: Starter ? (FULLTHROTTLE)
Are there any differences in the b series starters that makes one better than another?
Old Nov 22, 2002 | 05:20 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
yeah, the B18C/B16B/B16A are jdm. extra 10% more starter "hp"
seriously, they are all the same, no benefit of one over the other.
Old Nov 22, 2002 | 05:22 AM
sackdz's Avatar
Default Re: Starter ? (rodney)
Wait I thought the teeth on the JDM were slightly different, hence the problems iwht starter grind on JDM Flywheels... ??
Old Nov 22, 2002 | 05:48 AM
Default Re: Starter ? (sackdz)
There are different manufacturers for teh starters them selves but the hole and bolt patten are teh same in the trans. My Hybrid had a JDM trans and B16 (american) starter. no problems.
Old Nov 22, 2002 | 06:09 AM
Rodney's Avatar
TODA flywheel here,usdm starter, no grinds. i think all that grinding referred to the JUN flywheels, that grind jdm or not.
Old Nov 22, 2002 | 06:19 AM
sackdz's Avatar
I've heard grind stories from Spoon as well.
I thought someone said the tooth profile on the USDM starter was slightly different than the JDM. Which is why when you use a JDM flywheel (Jun, TODA, Spoon, etc) it might grind.
sack-who has a SPoon fw that does not grind.
[Modified by sackdz, 10:19 AM 11/22/2002]
Dekorum
Dec 6, 2013 06:56 AM
Big Money D
Dec 12, 2005 09:01 PM
Waachback
Jun 5, 2003 03:09 PM
BlackGSR
Dec 21, 2001 12:37 PM
