Squeaking in Steering Column?
Old Oct 7, 2002 | 10:47 AM
onyx00's Avatar
Default Squeaking in Steering Column?
It sounds like rubber rubbing against metal. The dealer said it was probably just some rubber gasket that is where the steering column goes through the floor of the car. The problem is there sometimes, but will usually go away.
Has anyone else ever had this problem? Is it hard to replace the gasket?
Old Oct 7, 2002 | 10:50 AM
Flux's Avatar
Default Re: Squeaking in Steering Column? (onyx00)
This is a common problem - it is a bearing in the steering column that has gone dry and needs to be lubricated. Take it to the dealer and they should fix it under warranty (if you have on still...)
Old Oct 7, 2002 | 10:52 AM
onyx00's Avatar
Default Re: Squeaking in Steering Column? (Flux)
Yeah; alright, next oil change will have it done.
Got any page number in the Helms where I can look at the part? Just want to be familiar with stuff in case dealer gives me ****.
cbp_crx
Feb 7, 2006 02:34 PM
RiCE On IcE 2
Dec 20, 2002 12:43 PM
01PYTypeR#1140
Nov 19, 2001 07:19 PM
01PYTypeR#1140
Nov 19, 2001 09:47 AM
