Spoon LSD
Old May 10, 2002 | 11:09 AM
citanest's Avatar
New User
Default Spoon LSD
Does anyone know who make them? Does it require a lot of maintenance compare to stock?
Old May 10, 2002 | 11:12 AM
IntegraT's Avatar
Default Re: Spoon LSD (citanest)
Honda, no
Old May 10, 2002 | 11:47 AM
spoonek4's Avatar
KAAZ as I know
Old May 10, 2002 | 11:48 AM
Eskimo's Avatar
I would rather get Quaiffe, if you're forking over for an aftermarket LSD.
Quaiffe > Spoon
Old May 10, 2002 | 11:52 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Spoon LSD (Eskimo)
Quaiffe > Spoon
Quaife = 1 way, Spoon = 1.5 way. Spoon is lighter weight, 1.5 way and clutch-type.
I went with the Spoon over the Quaife. The quaife is like a stock unit, only a little better.
Old May 10, 2002 | 11:53 AM
Hybrid ctr's Avatar
Default Re: Spoon LSD (Todd00)
ATS
Old May 10, 2002 | 11:55 AM
Mike M's Avatar
Founding Member
Id go with an ATS unit.
Old May 10, 2002 | 12:18 PM
AJ PwR's Avatar
Default Re: Spoon LSD (TypeRmsm)
ATS are awesome. I am running Spoon and itis definitely better compare with the KAAZ that I used to have. KAAZ only locks a bit better over stock and I think it is quite mild.
Old May 10, 2002 | 12:37 PM
BryanSprinkel's Avatar
Default Re: Spoon LSD (AJ PwR)
Can you really feel the difference compared to the stock LSD
Old May 10, 2002 | 12:40 PM
spoon_ek9's Avatar
Default Re: Spoon LSD (BryanSprinkel)
of course.
Old May 10, 2002 | 12:46 PM
citanest's Avatar
New User
How much maintenance is required for the spoon unit, as well as the ATS unit?
Old May 10, 2002 | 02:29 PM
AJ PwR's Avatar
A little bit on with the KAAZ but bigger differnece with the Spoon.
Old May 10, 2002 | 02:31 PM
SpecR_EK's Avatar
New User
This might be silly question, but compares to a 1 way LSD, how would a 1.5 way affect turn in and acceleration out of corners as well as the car's line? I've been curious as to how the 1.5 way would make the car handle on the track compared to the stock diff.
Old May 12, 2002 | 11:59 PM
citanest's Avatar
New User
Default Re: Spoon LSD (SpecR_EK)
If it's clutch type LSD like the Spoon or ATS, what type of transmission oil is required? Also, how long will it last before the the plate has to be changed?
Old May 13, 2002 | 03:03 AM
RagingAngel's Avatar
for KAAZ they recommend their own oils.....
Endless offers their diff fluid.
Amsoil seems to work for some....as does Redline...
I dunno what the preferred oil of choice these days are....it's probably Endless.
The plates have to be changed....well depends on how hard you drive.
Old May 13, 2002 | 05:17 AM
What do you feel with the spoon, that isnt there with the stock?
thanks
DJhondaR
Sep 27, 2004 07:38 AM
ahki
Sep 26, 2004 11:25 PM
kibbi
Nov 3, 2003 07:10 PM
berkel
Jul 5, 2001 10:20 AM
