Speed Sensor help
Old May 15, 2012 | 06:51 AM
PsychoRex's Avatar
Icon3 Speed Sensor help
Got a 96 ITR engine & my speed sensor is toast / What other year honda speed sensor's can I put?
Old May 15, 2012 | 07:40 AM
justjdm's Avatar
Default Re: Speed Sensor help
What trasnmission you have?
Old May 15, 2012 | 07:51 AM
94rs-turbo's Avatar
Do you need just the sensor or the entire gear n all?
Old May 15, 2012 | 03:20 PM
racebum's Avatar
gsr is comparable for sure
not 100% sure on the LS but it might be since the 94+ uses the s80 case, you would have to check part numbers
Old May 15, 2012 | 03:41 PM
Hasport's Avatar
any hydraulic speed sensor 92-01 will work
b or d series
Old May 15, 2012 | 05:05 PM
Aesthetic Gains's Avatar
Dos Pupusas
b or d series
^ This
Old May 16, 2012 | 01:35 PM
PsychoRex's Avatar
S80
Old May 16, 2012 | 01:36 PM
PsychoRex's Avatar
The entire thing
Old May 16, 2012 | 01:37 PM
PsychoRex's Avatar
b or d series
Sounds good thanks.
Old May 20, 2012 | 08:39 AM
PsychoRex's Avatar
Actually i just need the sensor / The engines rpms won't go lower than 2k rpms & the idle seems go up & down slightly. Also my 2 step won't go away even when am cruising, the engine is only reving to 3k, thats where my 2 step is.
Old May 20, 2012 | 10:02 AM
JDM illmatic's Avatar
You might want to rephrase your question.
thannon2
22
Jan 20, 2009 08:04 PM
thannon2
Jan 16, 2009 01:59 PM
