Spec B Question
Old Aug 27, 2001 | 10:43 AM
gina's Avatar
New User
Default Spec B Question
If I were to put spec b's, cam gears, retainers and valve springs in my car. What other minimum mods would I need to do for it to run well? I already have Mugen Header, Mugen Exhaust, AEM CAI and test pipe.
Thanks!
B18CXr's Avatar
Default Re: Spec B Question (00 Type R Chick)
VAFC............
Old Aug 27, 2001 | 10:47 AM
Dipshit Dan's Avatar
ECU upgrade or progammable ECU system might be recommended.
Old Aug 27, 2001 | 10:53 AM
gina's Avatar
New User
Default Re: Spec B Question (God)
Is the ECU necessary immediately? or is that something I can do later once I want to tune it better?
Thanks so much for your help guys!
Old Aug 27, 2001 | 10:54 AM
ZygSpeed's Avatar
Default Re: Spec B Question (B18CXr)
VAFC............
The bigger cams like the JDM spec headers better than the USDM versions, for the obvious reason (larger dia. collector).
So, even with your present Mugen (USDM?) setup ....
Old Aug 27, 2001 | 10:55 AM
Back in Black's Avatar
Rather OG
No, the ECU is not an immediate requirement.
B18CXr's Avatar
ECU is not needed.
Old Aug 27, 2001 | 10:59 AM
VAtypeR00@work's Avatar
Banned
ECU is not needed.
yeah what he said, the Vafc will be fine for now, down the road pick up a hondata or power FC, if you have someone to tune them.
hmm, could have saved you a few dollars about 6 months ago good luck!
Bryan
gina's Avatar
New User
Ok so basically all I need to get them installed is a V-AFC?
Old Aug 27, 2001 | 11:00 AM
gina's Avatar
New User
Yeah I know Bryan but I didnt have the $$ a few months ago....
Old Aug 27, 2001 | 11:01 AM
Black R's Avatar
25 Year Member
yup.
and a 2.5" collector header, as ed (zygspeed) has hinted...
If you have a jdm mugen header, vafc is all you need for the intended mods.
Join the family.
*OT: y'know honda should really have toda, spoon, and mugen products in their service shops... I mean at this rate, they should be honda optional equipment! All itr's will eventually have them, right?
Old Aug 27, 2001 | 11:04 AM
ZygSpeed's Avatar
Default Re: Spec B Question (Black R)
Lets keep this on a need to know basis. hehehe
As in, not everybody needs to know what's under the hood!
P.S. Looks like Comptech has the H/A OEM market (dealer installed warranty and all).
Old Aug 27, 2001 | 11:58 AM
Reid's Avatar
Global Moderator
Default Re: Spec C Question
On a semi-related note, hopefully soon I will begin my ITR project:
Spec C's, TODA valvesprings, Portflow retainers, Spoon cam gears, TODA ITB's, TODA header, 2.5" exhaust, Power FC.
I'm still unsure as to what kind of fuel system I will need. Any suggestions? With these power mods and suspension and brakes by Spoon, I'll teach those pesky M3 drivers a thing or two on the track
Old Aug 27, 2001 | 12:00 PM
Jason's Avatar
00 Type R Chick...I thought you were selling your car?
Old Aug 27, 2001 | 12:02 PM
gina's Avatar
New User
Default Re: Spec B Question (typer98)
Trying to keep her. I have got too much time, love, money into it to give her up so soon.
Old Aug 27, 2001 | 12:03 PM
Jason's Avatar
I hear ya, I was surprised when I saw your post about selling it...good to hear you're keeping it...
Old Aug 27, 2001 | 12:19 PM
FAST94GSR's Avatar
New User
Default Re: Spec C Question (Reid)
You're gonna need higher compression pistons(12:1 or more!). Specifically what do you mean when you want suggestions for fuel systems? You'll probably want to go with a higher volume fuel pump. Power FC is nice but I'd rather go with a hondata. 310 injectors
gina's Avatar
New User
ME TOO
Old Aug 27, 2001 | 12:26 PM
CPR's Avatar
CPR
I think I'm gonna add "Gurl" or "Chick" to my username so more people will check out my posts!
[Modified by CPR, 5:13 PM 8/27/2001]
Old Aug 27, 2001 | 12:27 PM
gina's Avatar
New User
Default Re: Spec B Question (CPR)
Old Aug 27, 2001 | 12:30 PM
A11MotorR's Avatar
New User
An unrelated note! I'm picking up Apexi VAFC 4 $230 in Hong Kong. Pretty CHEAP eh?
Old Aug 27, 2001 | 12:41 PM
ZygSpeed's Avatar
I think her popularity on the board grew dramatically after she posted a few pics.
Old Aug 27, 2001 | 12:52 PM
Black R's Avatar
25 Year Member
Default Re: Spec B Question (zygspeed)
That's what I'm sayin!
To quote Jack: "F-Comptech!"
I'd rather get dealer installed warranty from toda, mugen, and spoon products!
Oh so sad that comptech has that spot in dealer stores!
[Modified by Black R, 10:44 AM 8/28/2001]
Old Aug 27, 2001 | 12:58 PM
ZygSpeed's Avatar
Maybe the reason Comptech is OK w/dealers is that it might just be considered a light mod, whereas the rest of the "good" stuff gets ya throwing codes and stuff (for example w/properly tuned spec B's).
After all dealers still have to do stuff that's emissions legal (for the most part), whereas the rest of "US" don't always make that a priority.
So much for the serious stuff, when we doing Deal's Gap?
Old Aug 27, 2001 | 02:19 PM
2fcknfst's Avatar
Spend the money and get the appropriate ECU upgrade.
I am currently using Yoshio's, and although I had to tune (fine) the fuel, the basic ignition and fuel curves are much better suited to the Spec B's than the stock ECu and program is.
This is why he sells the cams WITH the ECU program. A VAFC will only allow for fine tuning of the fuel... not ignition.
Hope this helps...
