Spark Plug question..
Old May 19, 2006 | 02:25 PM
jdm_DC2R's Avatar
Default Spark Plug question..
i have a spark plug question, (yes i did a search, got nothing) so anyways, what plugs do u guys use? this is for a b18c-r motor, 96 spec.
thanks!
Old May 19, 2006 | 02:50 PM
jmk2888's Avatar
Default Re: Spark Plug question.. (jdm_DC2R)
NGK PFR7G-11 which is OEM JDM ITR Plugs.
Temp. is 7 due to High Compression.
Old May 19, 2006 | 03:26 PM
jdm_DC2R's Avatar
are those only available thru honda/acura dealer, or i can get them at any auto store?
Old May 19, 2006 | 04:04 PM
JjuuN R's Avatar
you searched?? really??... i mean, i really don't mind old stuff coming back to shed new lights on things, but don't say you searched when i come up with over 100 topics in 5 seconds of searching, for the Type-R Forum
what ngk spark plugs
Forum » Integra Type-R
Creator » digital sol 9:07 AM 3/1/2006
by splitime 16
Recommend new sparkplugs
Creator » powersteer 7:37 PM 2/19/2006
by powersteer 9
What spark plugs should I buy for my 98 Type R???
Creator » infulleffect 6:30 AM 12/28/2005
by infulleffect 14
torque specs for spark plugs?
Creator » Black R 12:48 PM 10/13/2005
by Booker 6
Any of you order your spark plugs from clubplug.net?
Creator » cruzersi99 9:07 AM 9/15/2005
by cruzersi99 3
Spark plugs
Creator » wpsadmin 2:40 PM 9/9/2005
by KOALA YUMMIES 8
Spark Plugs for R
Creator » dc4R 3:43 PM 7/26/2005
by realis9 5
Will OEM prelude spark plugs fit an ITR ? recomendable ?
Creator » Kavehman 8:40 PM 7/21/2005
by ITR#132 13
ows double iridium spark plugs
Creator » an2ny888 3:15 AM 4/24/2005
by an2ny888 1
A little oil on the spark plugs.....
Creator » Flux 9:25 PM 4/23/2005
by TypeR15 9
CHeck my spark plugs
Creator » petrv 3:19 PM 4/2/2005
by TOP END MS 21
spark plugs
Creator » Art Vandeleigh 11:34 PM 3/29/2005
by dk127 9
Spark Plugs 101, for those who like to learn.
Creator » Bbasso 11:13 AM 3/29/2005
by Type-R Yo! 2
best Spark Plugs out there for ITR..
Creator » wpsadmin 4:48 PM 3/1/2005
by mugenracer 21
another question about boost + high compression ratio re: spark plugs.....
Creator » Black R 8:05 PM 2/9/2005
by vtec.dc2 3
Turbo Type-R Spark Plugs.
Creator » 200cs 5:40 PM 1/31/2005
by ForceFedDetroit 10
spark plugs STUCK, how to remove? ( 1 2 )
Creator » RTW DC2 12:02 PM 1/16/2005
by RTW DC2 35
Which spark plugs?
Creator » Chiller 9:18 AM 10/29/2004
by white rocket 21
NGK Spark PLUGs??
Creator » jdmitr01 10:57 PM 10/8/2004
by mugenracer 11
Spark plugs and JDM vs. USDM ITR motor
Creator » NXSpoon 1:22 AM 10/7/2004
by voofee 5
spark plugs vs fuel consumption
Creator » voofee 12:17 PM 8/16/2004
by DutchITR1689 7
Spark plugs, ctr engine
Creator » Ricochet. 4:44 PM 8/11/2004
by Ricochet. 1
maintenance: spark plugs @ 55k mi.
Creator » kepani 10:17 PM 7/12/2004
by B2FiNiTY 17
Can a 3/4 turn when installing spark plugs damage head threads? ( 1 2 )
Creator » ITRFetish2000 12:10 PM 5/21/2004 30
Torque spec for spark plugs?
Creator » ITRFetish2000 7:47 PM 5/9/2004
by BauleyCivic 13
Spark Plugs white and black???
Creator » 98cwitr 1:52 PM 4/29/2004
by RTW DC2 6
OIL around my spark plugs.....please assist!
Creator » TypeRuz 4:35 PM 4/27/2004
by DragII 9
Hi. I have questions about spark plugs.
Creator » itr1244 4:24 PM 4/26/2004
by Rdriver 12
OEM SPARK PLUGS OR NGK
Creator » mikestypeR 10:33 AM 4/5/2004
by 04S2KGirl 16
Help: Spark plugs are white - running lean?
Creator » valentinecr 11:37 AM 3/22/2004
by integrasi 9
Spark plugs are freaking WHITE...
Creator » RTW DC2 10:34 PM 3/13/2004
by RTW DC2 20
ITR and GSR spark plugs... the same?
Creator » 4door-r 2:10 PM 2/29/2004
by sgT 3
urgent oil leak question in spark plugs
Creator » TypeR15 10:46 PM 2/28/2004
by TypeR15 10
Changing spark plugs ( 1 2 )
Creator » RGoose18 6:11 PM 1/9/2004
by JUN.R 37
Spark plugs, What do you have in your car right now? ( 1 2 )
Creator » Bbasso 9:50 AM 12/11/2003
by NBP #0933 33
Who's using these spark plugs??
Creator » hYpE-R-29 10:38 AM 12/10/2003
by DsR 7
Spark plugs?
Creator » ITR23 8:08 PM 10/13/2003
by 00 FBP ItR 10
Stock spark plugs VS. Denso Iridiums......
Creator » TypeRuz 6:25 AM 10/7/2003
by 1OPTION 8
Spark plugs for CTR
Creator » turbo se 8:01 AM 9/9/2003
by turbo se 1
What kind of spark plugs are these?
Creator » hYpE-R-29 8:04 PM 8/21/2003
by Maximus 10
Gapping of spark plugs
Creator » itr817 7:10 PM 7/26/2003
by Boges 7
what spark plugs are you guys running ? ( 1 2 )
Creator » SPOONfdEK 3:51 PM 7/1/2003
by Jspectyper 26
itr spark plugs
Creator » turkdog 7:09 AM 6/24/2003
by turkdog 5
Spark Plugs
Creator » ITR292 3:43 AM 5/31/2003
by ITR292 1
What kind of spark plugs do you recommend and gap?
Creator » ericlee303 7:12 AM 5/28/2003
by RaVAGE00 2
What is this stuff on my spark plugs!? ( 1 2 )
Creator » B2FiNiTY 10:37 AM 4/3/2003 34
spark plugs for built all motor engine
Creator » YellowR2000x2 3:31 AM 3/31/2003
by RICHJ 16
Spark Plugs
Creator » all stock 6:34 PM 3/25/2003
by sgT 2
spark plugs...can you clean them?
Creator » RTW DC2 11:14 AM 3/19/2003
by RTW DC2 3
Are these Iridium Spark plugs still good?
Creator » nEoMuGen 9:31 PM 3/14/2003
by .RJ 7
NGK BKR-6E11 spark plugs, come correctly pre-gapped?
Creator » Mike95lude 9:39 AM 2/28/2003
by AzSi22 13
Cleaning spark plugs
Creator » ITR 98 1162 12:55 AM 2/11/2003
by nfn15037 4
spark plugs
Creator » 2001itr534 4:48 PM 1/16/2003
by 2001itr534 1
Are theses NGK spark plugs good for the R?
Creator » B2FiNiTY 12:47 AM 1/16/2003
by spoon_ek9 22
which tool to properly gap spark plugs?
Creator » magic hat #9 8:55 PM 1/13/2003
by magic hat #9 15
Just changed the Spark Plugs & Wires for the first time. Some things i noticed and some questions.
Creator » Cyborg Ninja 9:38 PM 1/9/2003
by ITR#132 14
Old May 19, 2006 | 04:35 PM
jdm_DC2R's Avatar
holy ****... well i did search i typed in the search field "spark plugs" and i got nothing...weird...anyways, thanks for the help.
Old May 19, 2006 | 04:52 PM
jmk2888's Avatar
Default Re: (jdm_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">are those only available thru honda/acura dealer, or i can get them at any auto store?</TD></TR></TABLE>
I bought them at http://www.sparkplugs.com
Just put in the Item# of the plug and it'll come up.
It took like 4 days to arrive for me
Old May 19, 2006 | 05:06 PM
jdm_DC2R's Avatar
^^ thanks bro!
Old May 19, 2006 | 06:33 PM
Kyoto now's Avatar
If you dont feel like waiting, Nippon Denso makes an Iridium plug that retails for about $13.00 each. It's not an OEM plug but they're great. I was looking at a dyno chart for a 94 boosted EG, and the Denso plugs added 16 WHP. Plus, other benefits are smoother idle and acceleration.
Old May 19, 2006 | 07:11 PM
KayOs's Avatar
Default Re: (DA9 Purist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist &raquo;</TD></TR><TR><TD CLASS="quote">and the Denso plugs added 16 WHP. </TD></TR></TABLE>
Yeah, and an air filter added 10 hp ......
Old May 19, 2006 | 07:40 PM
dc2r01's Avatar
JUNR is the new search **** :D
Old May 19, 2006 | 08:10 PM
JjuuN R's Avatar
Default Re: (dc2r01)
lol
motegicivic
Mar 17, 2012 04:28 PM
spintboy
Apr 20, 2008 06:15 PM
millsd4
Feb 16, 2008 06:52 PM
Jesse H
Oct 25, 2001 09:48 PM
