shifting mistake and an engine light.
Old Nov 2, 2001 | 03:17 PM
Misfit's Avatar
Default shifting mistake and an engine light.
I fugged up tonight and shifted from 3-2 at about 9 grand. engine light came on and my idle sucks now. do you think i screwed my valves or something? I am going to acura tomarrow to get it checked out......
Old Nov 2, 2001 | 03:19 PM
Black R's Avatar
25 Year Member
Default Re: shifting mistake and an engine light. (ralph wiggum)
do not drive it anymore!
your valves are fucked
pray you didn't drop one...
Old Nov 2, 2001 | 03:21 PM
Misfit's Avatar
Default Re: shifting mistake and an engine light. (Black R)
wow. I am soo depressed now. i ran a 19.8 cause i slamed on the brakes and coasted home
Old Nov 2, 2001 | 03:22 PM
Misfit's Avatar
i will call them to tow it tomarrow morning. At least i don't have to work tomarrow.
citanest's Avatar
New User
Do not drive to avoid any further damage!!!!! Your valves are bent for sure!!!!!
[Modified by citanest, 4:26 PM 11/2/2001]
Old Nov 2, 2001 | 03:23 PM
Misfit's Avatar
Default Re: shifting mistake and an engine light. (citanest)
it happened 3 miles from home. i coasted it there. I did it like 20 minutes ago.
Old Nov 2, 2001 | 03:26 PM
Pinhead's Avatar
New User
yea your valves are definitely bent....same thing happened to me..your car sounds like a powerful v8 and it's quite expensive to fix i say just buy skunk2 valves they are probably cheaper and better than the type r ones...just my .02
Old Nov 2, 2001 | 03:27 PM
AllMotorMadness's Avatar
bent valves for sure.......do a compression test
Old Nov 2, 2001 | 03:28 PM
Misfit's Avatar
Default Re: shifting mistake and an engine light. (AllMotor_2.0L B18C5)
is this under warranty?
hybrid_eg's Avatar
yeah you fugged your valves.. check this.. last month, one night coming back home i was so tired that i couldnt even feel my hands.. i was doing like 90-100 redlined 4th.. slowly try to move to 5th.. i had no strenght to push the damn shifter far right and just move it up... 3rd!! release the clutch semi-slowly.. at that instant i was in a tunnel.. all i saw was that brigth amber needle and 10K!!! i thought it was over.. so i clutch in and start yelling.. then slap it into 5th and gas it.. to see what happens.. all seemed fine.. i guess luck.
if i were you take it back to the dealer and tell them it happened out of the blue.. just pretend you dont know what's going on.. hopefully they will replace it for free
Old Nov 2, 2001 | 03:31 PM
Misfit's Avatar
Default Re: shifting mistake and an engine light. (hybrid_eg)
i need to wash the shoe polish off my windows for sure
Old Nov 2, 2001 | 03:33 PM
yoshi234's Avatar
I shoot brides
but don't be suprised if they don't cover it under warranty. It's not a factory defect afterall.
yoshi - who hasn't mis shifted yet *touches w00d*
Old Nov 2, 2001 | 03:34 PM
Misfit's Avatar
Default Re: shifting mistake and an engine light. (yoshi234)
thanks guys you are all awesome. that was the first time i missed shifted too. touches wood also. but feels it is too late
Old Nov 2, 2001 | 04:43 PM
Warren's Avatar
Wrong-Way Wang
You probably bent all your exhaust valves. Expect about a $600-800 repair bill.
No it's not covered under warranty cuz you fugged up, and not the car.
Warren, aka Zingerboy
Old Nov 2, 2001 | 05:59 PM
arren123's Avatar
Default Re: shifting mistake and an engine light. (Warren)
How about upgrading your valve springs and retainers just in case you accidentally do it again.
Old Nov 2, 2001 | 06:20 PM
tjtruong's Avatar
New User
someone here in southern california got it covered under warranty. It just depends on the dealer and how sympathetic they are. Some are just nicer than others.. But all in all, just try the dealer.. they can't lose nothing..
Old Nov 2, 2001 | 07:15 PM
Type R 702's Avatar
New User
Default Re: shifting mistake and an engine light. (tjtruong)
Probably bent all your exhuast valves maybe your intake valves too and possilbly and hopefully you didn crack any valve guides.
Old Nov 2, 2001 | 07:32 PM
ITR 01-0907's Avatar
New User
Default Re: shifting mistake and an engine light. (Type R 702)
It sounds like you did bend some valves. Check what code it's throwing. i did the same thing, but i didn't do any engine damage. I did fry my clutch, and they replaced it under warranty.
good luck
[Modified by ITR 01-0907, 4:33 AM 11/3/2001]
Old Nov 2, 2001 | 11:53 PM
Black SVT's Avatar
Default Re: shifting mistake and an engine light. (ITR 01-0907)
It will be more than just bent valves.I did the same, it bent the #3 rod and bent 2 of the valves in cyl #3.I hope your dealer won't give you any trouble.The warranty reciept for my works was $4,200.It was an entire shortblock replacement along with the head being taken down and checked for possible damage plus 2 new valves.
Old Nov 3, 2001 | 06:54 AM
RJL's Avatar
RJL
New User
bye bye valves, well at least some of them
Old Nov 3, 2001 | 06:57 AM
i 4's Avatar
i 4
warranty should cover it, it happened to my friends R and they covered it, just dont tell them what really happened.
Old Nov 3, 2001 | 07:01 AM
D's Avatar
D
Ralph,
your application to we-todd-did racing is in the mail.
D
Old Nov 3, 2001 | 07:25 AM
Misfit's Avatar
Default Re: shifting mistake and an engine light. (D)
how are you liking the gun metals D? this sux. the truck just towed it to tischer acura about 5 mins ago. hope it all goes ok..
Old Nov 3, 2001 | 08:01 AM
Jason's Avatar
Default Re: shifting mistake and an engine light. (Badboy01GSR)
Bad Boy01GSR...just out of curiousity, where in TR do you get your work done? (assuming you don't do it yourself) when I left there, there wasn't too many tuners out there willing to take apart engines...
Old Nov 3, 2001 | 09:17 PM
MikeD's Avatar
New User
Default Re: shifting mistake and an engine light. (typer98)
I have heard the ECU will log overrevs (thus giving the dealer ammo to not fix it). I would reset the ECU just in case, and hopefully clear it. Just disconnecting the battery for a while will reset it. I don't know if it would clear the part you want cleared, but it is worth a shot.
