Rollcage question
Old Sep 11, 2002 | 11:50 AM
Jon7's Avatar
Default Rollcage question
Can someone fill me in on the details of going for a 4pt vs a 6pt, as well as autopower vs kirk? I realize a 6 pt is more extreme, but if my car will eventually be used as a track-only car within a yr or so, should I go for a 6pt initially?
Old Sep 11, 2002 | 11:54 AM
uNF$@#!'s Avatar
Default Re: Rollcage question (Jon7)
whatever race guidelines you need to follow
if none,
6pt is significantly heavier, and requires hacking of the dash.
4 pt is lighter, easier to install (imho) but provides less safety
Old Sep 11, 2002 | 11:57 AM
Big Phat R's Avatar
4 points are way easier to install (and remove if necessary). Both the Kirk and Autopower 4 point roll bars are fairly heavy but good enough for most purposes.
A 6 point will generally stiffen the chassis much more. Most of the bolt-in 6 pts have the front bars come in front of the dash - which hampers ingress/egress into the driver's seat - especially if you have a racing bucket seat. What kind of cage you get depends on how crazy you want to go (i.e. full race "cage"). I went with a 6 point that punctures the dash around the window vent area to make getting in and out of my track car easier. If you choose to run door bars you will have to lose the skins on the insides of the door. If you want to install foot boxes and such you will likely have to remove the entire interior.
Chromoly cages are lighter but are difficult to weld together properly. Special equipment and a talented welder is required = $$$$$
Plan for some downtime if you go with a 6 point.
Cusco also makes nice bolt in 6 point.
Old Sep 11, 2002 | 11:59 AM
Back in Black's Avatar
Rather OG
Default Re: Rollcage question (Soup ****)
A 6-point does not necessarily require hacking of the dash. Most bolt-in applications do not.
My vote is for a 6-point or 8-point. Go weld-in if you have the dough.
Jason-
who's trying to budget a weld-in cage for next season...
Old Sep 11, 2002 | 12:11 PM
BryanSprinkel's Avatar
Default Re: Rollcage question (Jason Franza)
Jon'
All you really need is the 4pt. You are only planning to do a few events a year, and just schools, no wheel to wheel racing.
Auto Power
Old Sep 11, 2002 | 12:14 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Rollcage question (BryanSprinkel)
Yah, Autopower work for me. I`ve had 3.
Also, 6-point "bolt-in" cages usually do so w/out chopping the dash. Autopower, Cusco, Kirk, etc.
ryan
Old Sep 11, 2002 | 12:18 PM
Rob :190:'s Avatar
Default Re: Rollcage question (vtecvoodoo)
ya'll know of some websites to look at for prices, info, for people interested?
rob- who is very interested in safety since he plans to track his AARRR soon
Old Sep 11, 2002 | 12:21 PM
Rather OG
Default Re: Rollcage question ( Rob)
http://www.ioportracing.com is where I purchased my AP 6-point from.
Safety is good
Old Sep 11, 2002 | 12:28 PM
Johnny Tran's Avatar
i like monkee barz.......they seem safe with my 1.5" 4 pt harnesses with plastic buckles....(dont worry, i bolt the harness's to the rear seat belt location for safetys sake)
Old Sep 11, 2002 | 12:30 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Rollcage question (Johnny Tran)
harness? I pretend I`m in a kart and don`t wear them
Old Sep 11, 2002 | 12:51 PM
the best is when i see how many buddies i can fit in the rear area of the cage....then drive around on the wrong side of the road and play chicken with oncoming traffic.
Old Sep 11, 2002 | 01:04 PM
slowassR's Avatar
I would go with a 6pt in your case (only track driving). I will put one in soon but im going to the 4pt (daily driver).
Old Sep 11, 2002 | 01:20 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
If you're planning on doing SCCA competition, you may want to check last months fast track. The new rule is that cages must have a diagonal cross member, even if it's removable.
Old Sep 11, 2002 | 01:51 PM
Big Phat R's Avatar
Default Re: Rollcage question (newt2)
Does it mention a specific orientation of the diagonal cross member?? Some people seem to think that the top point of the cross member needs to be behind the driver's head. I've seen cages with crossmembers in both orientations. i.e. / and \
BPR - who thinks a triangle is a triangle
Old Sep 12, 2002 | 06:45 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Rollcage question (Big Phat R)
It didn't specify in the bulletin.
Old Sep 12, 2002 | 06:55 AM
Dave-ROR's Avatar
Don't listen to soup **** regarding the dash
PHR: The Kirk Cage can be installed with door bars and stock door interior panels.
Old Sep 12, 2002 | 07:13 AM
ITR764's Avatar
Default Re: Rollcage question (SoFreshAndSoCleanClean)
i just need someone to sell me there 4pt wid removable center section
Old Sep 12, 2002 | 07:17 AM
Rather OG
Keith-
I'll give ya a great deal on an AP 6-point cage when I get my weld-in
Old Sep 12, 2002 | 07:44 AM
Anderson's Avatar
Old Sep 12, 2002 | 08:00 AM
Hooch'n's Avatar
Default Re: Rollcage question (Anderson)
Weld in=
Andy: Who has already looked at a couple of options for his 95 hatch!
Old Sep 12, 2002 | 08:19 AM
Floyd's Avatar
Default Re: Rollcage question (Hooch at 8400-RPM)
Can't you go wth a 4pt now and add the front section at a later date? I'm sure this isn't quite as rigid as a 6pt from the start, but it might be an option.
Old Sep 12, 2002 | 08:33 AM
ITR764's Avatar
Default Re: Rollcage question (Floyd)
i think AP offers that... you have to have the front welded to your current 4 pt bar.
Old Sep 12, 2002 | 08:50 AM
Ausmith's Avatar
Find a decent local race shop that does fab work. Have them build a custom cage to your specs.
King Motorsports will do a complete custom 8 point cage with NASCAR door bars for around $2000.
It's your ***... do it once and do it right.
Old Sep 12, 2002 | 09:16 PM
Jon7's Avatar
Default Re: Rollcage question (Ausmith)
Thanks for all the responses. At the moment, I think I'm leaning towards to the 4pt. Does it really matter to go with autopower vs Kirk? What are the differences between the 2?
Old Sep 12, 2002 | 09:21 PM
Yunisden R's Avatar
New User
If is a track car, go get yourself a 6 or 8 pt, weld please.
Dennis
