Is this right??? C-speed compression calc wrong?
Old Mar 20, 2003 | 07:06 PM
FOB's Avatar
FOB
Default Is this right??? C-speed compression calc wrong?
hey all, I've been reading post after post doing research and i'm getting confused. The C-speed calc says that CTR pistons in a B18C1/C5 yield 11.751778779507741:1 compression ratio, but why is everyone posting that it will yield anywhere from 12:1 to 12.5:1...who is right...i'm i setting up the calc wrong?
SETTINGS:
Block: B18C1/C5
Head: B16A/B18C5
Pistons: pct B16B
Headgasket: OEM 3 layer
Piston to deck height: B18C1/C5
Also...is a 11.8:1+ compression ratio to high for texas weather even if it was tuned?
Thanks in advance!
David
Old Mar 21, 2003 | 10:00 AM
sgT's Avatar
sgT
Default Re: Is this right??? C-speed compression calc wrong? (FOB)
Set piston to deck height to 0.00 and try again.
Old Mar 21, 2003 | 10:04 AM
TsunamiZC's Avatar
Default Re: Is this right??? C-speed compression calc wrong? (sgT)
oh..is that another dallas Type R i spy ?
Old Mar 21, 2003 | 01:44 PM
fowler!'s Avatar
CTR pistons in a B18C1 and a B18C5 will be quite diffferent.
Old Mar 21, 2003 | 01:47 PM
Footwork's Avatar
Should be 12.07013014931 blah blah @ 81.25 bore.
Paul
Old Mar 21, 2003 | 02:17 PM
YellowR2000x2's Avatar
Default Re: Is this right??? C-speed compression calc wrong? (Primo EF)
i live in south texas running 12:1 C/R and i have no problems so far...just get it tuned
Old Mar 21, 2003 | 03:02 PM
FOB's Avatar
FOB
setting piston to deck height to 0.00 makes the compression 12.9 to 1 ...thats alittle high isn't it?
Old Mar 21, 2003 | 10:13 PM
2fknlo's Avatar
What the max i could adjust the cam gears in a ITR with B18B pistons and Skunk stage two cams?
VVENOM800TT
Feb 17, 2011 02:48 PM
hytec
Oct 11, 2006 03:33 AM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
lilredhatch
Dec 22, 2004 03:48 PM
