Real quick question
Old May 23, 2003 | 06:05 PM
Denny's Avatar
Default Real quick question
to keep this type r related it involves my type r but anyways, how important is the dust cover for your brakes? i might put some calipers and these calipers involve cutting the dust cover. im too lazy to spend time doing that so i just want to remove it. is it okay to just take it off and not use it? thanks
Old May 23, 2003 | 06:08 PM
zer0zer0 TypeR's Avatar
Default Re: Real quick question (TypeR882)
if you can it doesn't hurt to bend them a little if you don't wanna remove the whole thing
Old May 23, 2003 | 06:18 PM
EleanoR's Avatar
Default Re: Real quick question (zer0zer0 TypeR)
From what i heard prior to my experience is that once you cut or remove the dust shields your brake rotors are no longer protected from the wheels 'throwing' up water onto them in the wet. This can cause the brakes to not work near as good IMO after i took them off so give yourself some more distance. The car will still stop but initial bite is horrible because water gets on the rotor. If you don't do Solo I or HPDE then it isn't worth it to cut them IMO
Old May 23, 2003 | 10:38 PM
Dr Pooface's Avatar
Default Re: Real quick question (EleanoR)
I have mine removed and drive in the rain no problem.
rollercosta123
Mar 27, 2007 02:17 PM
Weston
Jul 1, 2002 05:24 AM
Conechaser
Feb 11, 2002 06:23 AM
serious
Sep 13, 2001 11:22 PM
serious
Sep 7, 2001 08:21 AM
