Quick ? for the stunnas :)
Old Oct 9, 2002 | 01:18 PM
Comp97GSR's Avatar
Default Quick ? for the stunnas :)
Today driving home from work, I went to pass a fool and down shifted to 4th gear. As I went to change lanes another driver took my spot so I remained in 4th @ about 5k till I could make my lane change. As I was holding the rpm's steady (at part throttle) I felt a surging from the motor. As I stepped back into it the motor reacted as usual. Has anybody else experienced this or is something out of wack? Thanks.
Old Oct 9, 2002 | 01:19 PM
Chris N's Avatar
Default Re: Quick ? for the stunnas :) (Comp97GSR)
Explain what you mean by a surging from the motor?
Old Oct 9, 2002 | 01:22 PM
Comp97GSR's Avatar
Default Re: Quick ? for the stunnas :) (1107)
Felt like I was blipping the throttle.
Old Oct 9, 2002 | 01:26 PM
Chris N's Avatar
I'm not sure what that is. Mine does not do that. Anyone?
Old Oct 9, 2002 | 01:27 PM
AssPenny's Avatar
Did it do it just once, or can you make it do it all the time?
Old Oct 9, 2002 | 01:29 PM
Cosworth's Avatar
probably your radiator fan kicked in... just like when you're sitting at a light and your fan kicks in and the motor jump by 2-300 rpm. That's my guess... I don't know why you would've felt it that hard though.
Comp97GSR's Avatar
Default Re: Quick ? for the stunnas :) (AssPenny)
After it happened I was able to repeat it.
Oh and it doesn't do it in gears 1,2 and 3
[Modified by Comp97GSR, 4:34 PM 10/9/2002]
Old Oct 9, 2002 | 03:13 PM
Tommy_Gunns's Avatar
Did you have a/c on?
Old Oct 9, 2002 | 03:21 PM
NunRacer's Avatar
Default Re: Quick ? for the stunnas :) (Tommy_Gunns)
I'm betting on the a/c
Old Oct 9, 2002 | 03:32 PM
o_Rage_o's Avatar
Default Re: Quick ? for the stunnas :) (NunRacer)
yea possibly ac or rad fan, and you would feel it like that because you were driving at higher rpm in a lower gear
-Rage
Old Oct 9, 2002 | 04:09 PM
Napolean Solo's Avatar
Default Re: Quick ? for the stunnas :) (o_Rage_o)
it was VTEC
Old Oct 10, 2002 | 01:32 PM
Comp97GSR's Avatar
Default Re: Quick ? for the stunnas :) (Napolean Solo)
Thanks for the input!!! The a/c wasn't on and wasn't the rad fan. Unfortunately I have a problem with the vtec solenoid or something. It won't engage anymore and when it did it used to click when activating and deactivating. Any ideas? I am thinking I will change the lost motion assemblies and clean the vtec solenoid first. Second I need to find a JDM ITR t/b gasket or go back to the GeeSR t/b. I have a vacuum leak and Hondabond is not working. What do you guys think? Thanks..... John
Old Oct 10, 2002 | 01:58 PM
4-1-1's Avatar
Vtec?
Old Oct 10, 2002 | 02:08 PM
Comp97GSR's Avatar
Default Re: Quick ? for the stunnas :) (4-1-1)
Yes it has vtec. OH... Vtec. BTW, oil level is fine and doesn't lose any between oil changes.
untitled23
Sep 2, 2010 02:56 PM
static-x
Sep 27, 2007 08:03 AM
eg:R
Aug 19, 2007 12:44 PM
m1ndless
Jun 25, 2007 06:43 PM
STYLiNxCHiQ_DA9
May 12, 2006 09:49 PM
