quick problem removing suspension
Old Apr 2, 2003 | 09:48 AM
py1188's Avatar
Default quick problem removing suspension
Well I decided to get rid of the dust shields on my bilsteins that are all crunched up, but I seem to be having a problem remving the bilstein from the damper fork. I went at it for an hour trying to get that thing off and It didn't budge at all.
I tried wd-40 and liqud wrench, but nothing seemed to work
Any suggestions?
Old Apr 2, 2003 | 09:51 AM
Reid's Avatar
Global Moderator
Default Re: quick problem removing suspension (py1188)
You did remove the bolt holding the fork on right?
Old Apr 2, 2003 | 09:53 AM
py1188's Avatar
Default Re: quick problem removing suspension (Reid)
Yeah I just can't seem to yank it down from there
Old Apr 2, 2003 | 09:54 AM
Reid's Avatar
Global Moderator
Have you tried "pushing/pulling" opposite ends of the fork, in an attempt to "wiggle" it free from the shock?
Old Apr 2, 2003 | 09:55 AM
sackdz's Avatar
Try a BFH on the fork. I always have more trouble getting them back on then off. Makes sure you clean out the borre really well when its off.
Old Apr 2, 2003 | 09:57 AM
yellow blur's Avatar
Default Re: quick problem removing suspension (sackdz)
Did you remove the bolts through the shock mount yet? Maybe you might want to leave those two bolts in, and did you also take both bolts out of the fork? Take both bolts out and maybe try turning the fork from side to side?
I'm with Ed on this one, always have more problems putting the fork on than taking it off. Good luck.
Ed
Old Apr 2, 2003 | 11:09 AM
py1188's Avatar
Default Re: quick problem removing suspension (yellow blur)
I tried wiggling, but maybe not good enough, I'll try that when I get home
Thanks guys
unhappy_idle
May 16, 2006 09:22 AM
EJ20
May 27, 2005 12:16 PM
Full Race A6
Aug 5, 2004 11:30 PM
Origin
Feb 15, 2004 10:31 PM
