Quick coolant flush question
Old Nov 28, 2003 | 10:27 AM
davidnyc's Avatar
Default Quick coolant flush question
I need to flush all of the coolant out of the engine. I have the Helms and to fully flush the coolant I have to flush it from the radiator and engine block.
I know how to flush the radiator that is easy enough.
The question:
When I loosen the bolt on the block (the one next to the header) will coolant just start to flow out of the bolt hole?
The reason I ask, is that I don't want coolant all over the header and stuff. I just want to be prepared with the rate of fluid coming out of the block before I loosen that bolt. I guess I can cover things up with a plastic sheet or something.
Old Nov 28, 2003 | 10:28 AM
.RJ's Avatar
.RJ
Default Re: Quick coolant flush question (davidnyc)
heh, yeah if you're worried about keeping your header pretty, take it off
its a racekar now!
Old Nov 28, 2003 | 10:29 AM
TypeR 599's Avatar
It will be a big rush.. sort of like the oil pan bolt. it will start coming out towards the last few turns of the bolt. wear a glove
Old Nov 28, 2003 | 10:33 AM
davidnyc's Avatar
Default Re: Quick coolant flush question (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">It will be a big rush.. sort of like the oil pan bolt. it will start coming out towards the last few turns of the bolt. wear a glove</TD></TR></TABLE>
This is the EXACT answer I was looking for. I am doing it in my garage and wasn't sure if coolant will go all over the place. I'll try and stuff a bucket or something in there and cover my floor with plastic.
Old Nov 28, 2003 | 10:35 AM
davidnyc's Avatar
Default Re: Quick coolant flush question (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">heh, yeah if you're worried about keeping your header pretty, take it off
its a racekar now!</TD></TR></TABLE>
hahaha... true...
Old Nov 28, 2003 | 11:12 AM
RealTypeR2's Avatar
Just put a pan bucket underneath your car. If the fluid gets on your header, wipe it off. It is not going to harm it.. waste of time if you take your header off IMO. lol
Old Nov 28, 2003 | 01:21 PM
bus stop's Avatar
do it on your driveway and hose it down after you done.
btw.....you should do it now cuz it's raining outside
Old Nov 28, 2003 | 01:29 PM
davidnyc's Avatar
Default Re: Quick coolant flush question (WhosITR)
I am actually going to do it in February sometime, just preparing. I have to flush all the coolant out and then fill it with plain water. Just wanted an idea of what I was in for.
Old Nov 28, 2003 | 01:31 PM
bus stop's Avatar
if you're looking for a full flush, you may want to put a garden hose into the block to flush out all the coolant which may remain inside.
Old Nov 28, 2003 | 01:58 PM
magic hat #9's Avatar
i flushed the coolant out of my block and was not prepared for the gush of nasty, urine smelling coolant that went absolutely everywhere. try to have your catch can as close to the block hole as possible.
Tokonut
Mar 1, 2009 06:33 PM
ehonda1980
Jul 31, 2007 11:26 AM
91H4hatch
Dec 26, 2006 04:51 PM
LudeChild
Feb 4, 2005 05:33 PM
Rain_man
Oct 31, 2003 07:36 AM
