Question/ sanity check about the "check engine" light
Old Nov 19, 2001 | 08:07 PM
CW_97_ITR's Avatar
Default Question/ sanity check about the "check engine" light
My Type R is the first car I have owned that makes that scary sucking sound (the vaccum) when you take the gas cap off. I know that some verions of OBD 1 will turn the check engine light on if the gas cap is not on or the vapor recovery system stops working for another reason.
Tonight I was in a hurry when I stopped to get gas and just whipped the gas cap off not slowly at all. It made the sucking sound for a while (a few seconds), but I ran the tank down pretty low (put in 12 gallons, but that was really topped off. The needle went past the F).
I filled up, put the gas cap back on and hopped in the car. When I started it I noticed the check engine was blinking. It went out shortly, but it was the last idoit light on the dash to go out by a couple of seconds.
I shut the car off when I got where I was going, it sat for about 20 minutes I got back in and the check engine light did the same blinking thing.
I haven't been driving my R never long and ( I am kind of embarassed to say) I don't really know what the check engine light does norally when I turn the car on. I would think it would come on and the just go out, no blinking and quickly.
The car drives fine and still pulls like a donkey on crack when the v-tec hits.
I might be overly worried, but I wanted to make sure nothing was wrong. If you can share your ideas and experiances with this problem that would be great.
Thanks a lot
Matt
Old Nov 19, 2001 | 08:11 PM
Type Goch's Avatar
New User
Default Re: Question/ sanity check about the "check engine" light (CW_97_ITR_071)
dont worry about the gas thing making that vacuum sound. As for the CEL, did u figure out what it says?
Old Nov 19, 2001 | 08:12 PM
KF_S2000's Avatar
I've got an idea, but not 100% sure. Could it be that the gas cap didn't get reinstalled back on tight enough? I remember reading in my Civic Si manual that if the gas cap is loose, the check engine light will come on letting you know. Also, you're right, when starting the engine, the light should come on solid, then go out. This is just the first thing to come to mind... Hope this is all it is.
Old Nov 19, 2001 | 08:20 PM
Type Goch's Avatar
New User
Default Re: Question/ sanity check about the "check engine" light (cotton_lix)
On my Teg (LS) I think it is every 7500 miles or so it starts to flash for 10 seconds every time you start the car to alert you to the fact you need to service it (oil change, etc..). I assume the R has the same feature. After 10,000 it stays on all the time.. It is easy to turn off. On the right side of the steering wheel underneath the dash there is a hidden button which you hold down to turn the light off.
I was warned about the gas cap thing too, once I forgot to put on my cap and drove off and the light did not come on.. But Acura told me to make sure it clicks three times.
umm i think thats the maintenance required light.
Old Nov 19, 2001 | 08:21 PM
FULLTHROTTLE's Avatar
Is your check engine light flashing or your Maintenece required light flashing? Huge difference. Check engine light flash = Misfire that can cause Catalyst damage. Maint.Reqd. light flashing = your mileage indicates you need an oilchange and a tire rotation. Gas cap suckie noise, vapor recovery sytem fully operational.
Old Nov 19, 2001 | 08:24 PM
d8168055's Avatar
that flashing light is the "mantainence required" light.. not the CEL... its nothing to worry about... as for #071... i think that u either didnt close the cap tight enough, or u may have used the wrong octane fuel...
Old Nov 19, 2001 | 08:26 PM
CW_97_ITR's Avatar
Default Re: Question/ sanity check about the "check engine" light (Type Goch)
Thanks for your replies.
I will look into that hidden button on the dash to turn it off.
I did get right out and check the gas cap before I left the gas station, so I don't think that caused it. The car did just turn 6000 miles so I am thinking its time to change the oil and find that hidden button under the dash.
Thanks again.
Matt
Old Nov 19, 2001 | 08:28 PM
CW_97_ITR's Avatar
Sorry, it is the "Maintenance required" light.
Time for an oil change and rotate the tires.
Will the Maintenance Required light flash at every 6000 mile interval?
Thanks again.
Old Nov 19, 2001 | 08:41 PM
Type Goch's Avatar
New User
-Courtesy of Yoshi234
Old Nov 19, 2001 | 08:49 PM
Toda Party's Avatar
that picture is great
Old Nov 19, 2001 | 08:50 PM
CW_97_ITR's Avatar
OH yeah, gotta change the oil every 3000 miles without fail.
Freash oil is even more important with a motor with piston speeds this high.
Thanks for the sweet diagram, that will make finding that button much easier.
SLEEPIN-GSR
Jul 3, 2009 06:43 AM
cloin51
Honda Civic (2001 - 2005)
10
Dec 9, 2006 07:13 AM
PearlH22
Mar 29, 2006 11:18 AM
evergruven
Mar 10, 2002 06:48 PM
