Question for the Experts
Old Jan 9, 2002 | 12:52 PM
Solo2Vtec's Avatar
Default Question for the Experts
I'm installing a JDM 4into1 header on my 2000 LS/Vtec powered integra. And I am using a stock type r b pipe and muffler. My question is how long does the test pipe have to be between the header collector and b pipe. I'm not using the cat this is for off road use. I want to be able to get the pipe made at the muffler shop so I don't have to drive the beast off the header. I'm sure some of you have had a pipe made and know exact length.
Thanks
Old Jan 9, 2002 | 12:58 PM
Solo2Vtec's Avatar
Default Re: Question for the Experts (LSVtec2000)
ttt
Old Jan 9, 2002 | 01:06 PM
Chris's Avatar
I have the dimensions..Ill get them a little later. (I have to go into the attic and measure it.
Are you OBDII...will you need the 02 bung???
Old Jan 9, 2002 | 01:08 PM
Solo2Vtec's Avatar
Default Re: Question for the Experts (Chris)
Thanks Chris Yeah I am OBD2 but I won't need the bung. Can I ask how much you paid for yours? And its a 2 1/2 to 2 1/4 right?
Old Jan 9, 2002 | 01:41 PM
Solo2Vtec's Avatar
Anyone else? Please lol
Old Jan 9, 2002 | 01:47 PM
Chris's Avatar
Its actually close to 2 1/2 (60MM I think) all the way thorough. I just got a universal 2 1/2 in. 3 hole gasket from the muffler shop and it fit to the stock B-Pipe. Its one hell of a bottle neck, but I dont care for street performance....
I got mine from Godspeed. Cant remember how much.
I will get the length..brb!
Old Jan 9, 2002 | 01:53 PM
Solo2Vtec's Avatar
Thanks again Chris
Old Jan 9, 2002 | 01:58 PM
Chris's Avatar
Mine is 17.5 inches long.
Old Jan 9, 2002 | 02:36 PM
Solo2Vtec's Avatar
alright anyone else have the same setup? I would hate to have it made and it's to long or short.
Thanks
Old Jan 9, 2002 | 03:11 PM
Solo2Vtec's Avatar
N0 one else runs a JDM 4into1 on there R with the stock piping?
Old Jan 9, 2002 | 03:27 PM
Black R's Avatar
25 Year Member
.....well I run a toda racing header to a godspeed test pipe connected to my stock catback. fits fine. Should be the same as the jdm header.
Old Jan 9, 2002 | 05:06 PM
JPP's Avatar
JPP
I have a Spoon header and Godspeed special test pipe. I'm not sure of the exact lenght of the test pipe. I measured the stock cat. converter and it is 17 1/2". If I remember correctly the test pipe was the same lenght as the stock cat.conv.
Old Jan 9, 2002 | 05:19 PM
Chris's Avatar
Default Re: Question for the Experts (JPP)
I measured the stock cat. converter and it is 17 1/2". If I remember correctly the test pipe was the same length as the stock cat.conv.
YUP.
Old Jan 9, 2002 | 05:21 PM
Black R's Avatar
25 Year Member
yup.
Old Jan 9, 2002 | 05:33 PM
Willard's Avatar
16 5/8" is the length (from flange edge to falnge edge) of the test pipe in my garage.
Used with a stock cat back (ITR) and JDM 4 into 1 header on my DC2-R
Will
-who used the test pipe once
Old Jan 9, 2002 | 05:47 PM
SMSP's Avatar
Default Re: Question for the Experts (Willard)
Yeh, what he said.
I actually build the test pipes and cats to about 16-7/8". But that is measured from the B pipe flange to the flat surface of the donut, it's a little more accurate to set the length this way then measuring from the flare end of the cat/test pipe since the flare can vary.
Old Jan 10, 2002 | 08:03 AM
Solo2Vtec's Avatar
Default Re: Question for the Experts (SMSP)
Thanks again for all the help!
DOUBLExDEUCEx22
Jul 8, 2009 05:30 PM
CivSiClone_96
Sep 20, 2008 07:49 PM
chinkyEyez
Welding / Fabrication
Aug 21, 2004 10:54 AM
M0NEYnH0s
Jun 4, 2002 10:42 PM
Solo2Vtec
Jan 10, 2002 10:38 AM
