Question for the expert
Old May 10, 2005 | 06:59 PM
DC2TT's Avatar
Default Question for the expert
1 i need to know whether 80 inch oil cooler line is enough to locate oil cooler at the front of radiator?
2 To wire the jdm itr hid beside the 5 wires do i need anything else such as relay or fuse( it is a convertion to jdm hid light so basically every wire are original dc2 round light's wire)
Old May 10, 2005 | 07:06 PM
Chris F's Avatar
Default Re: Question for the expert (DC2TT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2TT &raquo;</TD></TR><TR><TD CLASS="quote">1 i need to know whether 80 inch oil cooler line is enough to locate oil cooler at the front of radiator?</TD></TR></TABLE>
Can you please rephrase the question?
A Greddy oil cooler fits... which one are you looking at?
Old May 11, 2005 | 10:03 AM
DC2TT's Avatar
Default Re: Question for the expert (Chris F)
i am using setrab and i am wondering is 2 80inch long oil cooler line enought to route the oil cooler to the front
Old May 11, 2005 | 10:50 AM
citrus3000psi's Avatar
it really depends on how you run the lines but eaisiest way to make sure is just get some string and run string from where you want the cooler to sandwhich plate in the back. Measure the string then. Leave a little slack since string is obviosuly a little more flexible then hose.
Old May 12, 2005 | 07:53 AM
DC2TT's Avatar
Default Re: (citrus3000psi)
i alreafy custom made the oil cooler line just need to know
Old May 12, 2005 | 09:11 AM
SecretAgent's Avatar
80" is 6' 4" so i would assume that's plenty if you have two of them. unless you're trying to mount the cooler in the trunk. but anyways, yeah, should be enough to mount the cooler in the fenderwell.
perseverance
Jan 15, 2012 05:44 PM
kay_animation
Jan 1, 2005 05:51 AM
VTECAcuraGSR
10
Jul 12, 2004 01:26 PM
revhigh96
Sep 6, 2003 08:19 PM
