problem pumping gas
Old Sep 6, 2004 | 01:35 PM
jaa1311's Avatar
Default problem pumping gas
For some reason I have not been able to pump gas into my car from 3 different gas stations! After i fully pull in the trigger on the pump it shuts off like the tank is full yet it is on empty. The only way i have been able to fill my tank is by lightly pulling the trigger on the pump and just adding little by little until its full. Anyone ever experience this problem or have any idea on what i can do to fix it?
Old Sep 6, 2004 | 02:10 PM
2slowgsr's Avatar
Default Re: problem pumping gas (jaa1311)
My moms cars(pontiac bonneville) is having the same problem. A local mechanic said that a tube in the gas tank is bent or broken, not letting the gas fill the tank quickly. He said she might have to replace the whole tank.
Old Sep 6, 2004 | 02:41 PM
Smitdog's Avatar
Default Re: problem pumping gas (2slowgsr)
Not really sure. I would pull the driver rear wheel take off the spalsh sheilds over the lines and inspect them. You need to get that fixed ASAP, Summit not this weekend but next.
Old Sep 6, 2004 | 02:57 PM
jaa1311's Avatar
Default Re: problem pumping gas (Smitdog)
Thanks guys. Steve the car runs fine, just dosent want to accept gas, so ill be ready for summit either way. You need me to book u a room??
Old Sep 6, 2004 | 03:00 PM
Smitdog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaa1311 &raquo;</TD></TR><TR><TD CLASS="quote">You need me to book u a room??</TD></TR></TABLE>
No thanks. I have it taken care of.
Old Sep 6, 2004 | 03:04 PM
jaa1311's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smitdog &raquo;</TD></TR><TR><TD CLASS="quote">
No thanks. I have it taken care of. </TD></TR></TABLE>
nice!
Nishant's Avatar
i'd at least take a look at it before summit, better to be safe
Old Sep 6, 2004 | 03:08 PM
jaa1311's Avatar
Default Re: problem pumping gas (Nishant)
def, ill check it out when i do my brakes, have fresh rotors from cobalt comming in and gt-sports and ultimates to put on
Old Sep 6, 2004 | 03:45 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaa1311 &raquo;</TD></TR><TR><TD CLASS="quote">def, ill check it out when i do my brakes, have fresh rotors from cobalt comming in and gt-sports and ultimates to put on </TD></TR></TABLE>
don't forget the fluid
Old Sep 6, 2004 | 03:50 PM
jaa1311's Avatar
yea, i guess fluid would b nice , they were outta super blue though when i called last week
Old Sep 6, 2004 | 03:55 PM
Nishant's Avatar
i have a liter sitting in my garage. try marketplace.s2ki.com
Old Sep 6, 2004 | 03:57 PM
jaa1311's Avatar
thanks
Old Sep 6, 2004 | 08:29 PM
hYpE-R-29's Avatar
i had the same problem...then i found out I had a dented gas tank...check that
Old Sep 6, 2004 | 09:08 PM
Mr.Fairlady's Avatar
Its honestly because its splashing on the nozzle.You may have to pull the tip out a little more to make sure and it will work!
Thats what happens to ALot fo cars I've ever filled up.The 350Z was notorious for doing that!
Try that!
Old Sep 7, 2004 | 03:57 PM
jaa1311's Avatar
Default Re: problem pumping gas (Mr.Fairlady)
thanks ill try that
bleedblue94
11
Apr 16, 2006 01:08 AM
bullethead399
May 10, 2005 06:20 AM
CHARD23
Feb 3, 2005 11:00 AM
pistol
Aug 16, 2001 10:43 AM
