Problem with header????
Old Aug 20, 2001 | 09:54 PM
r2fst4u's Avatar
New User
Default Problem with header????
I have a DC 4-1, AEM CAI and an Apex n1 on my 01 R. Ever since installed, I loss .2 in the 1/4 and running rich. The dealer claims it is the header because not enough back pressure. How is this possible if the JDM has a 4-1 and no problems?????
Old Aug 20, 2001 | 10:12 PM
SMSP's Avatar
Default Re: Problem with header???? (r2fst4u)
What DC?
Old Aug 21, 2001 | 01:28 AM
DutchITR1689's Avatar
Default Re: Problem with header???? (SMSP)
It's the USDM DC 4-1 I think. He is still using the stock cat. Does the car FEEL slower? Did you reset your ECU? There are many factors that could cause your 1/4 mile time loss. Don't expect too much from the DC 4-1 with stock cat.
Old Aug 21, 2001 | 04:09 AM
r2fst4u's Avatar
New User
Default Re: Problem with header???? (EuroITR1689)
It is the USDM 4-1. If it is the stock cat causing the problem, what should I get to correct this? Will I have a problem with emissions if I change the stock cat??
Old Aug 21, 2001 | 04:14 AM
The cat is just limiting your exhaust gas flow in such a way the you don't gain much from your DC header. You can get a High-flow cat or test pipe. You won't pass emission test with a test pipe. But how did the car FEEL after the mods? Stronger? No difference?
Old Aug 21, 2001 | 02:10 PM
r2fst4u's Avatar
New User
The car felt like it hit v-tech harder but it lost .2 in the 1/4.
DANG YO
Jan 5, 2005 01:50 PM
jweezy225
Nov 3, 2004 02:24 AM
thanatos2k
Jul 15, 2003 10:15 AM
no2unenolife
May 22, 2003 03:48 PM
pistol
Nov 26, 2002 11:26 AM
