Problem!
Old Mar 21, 2004 | 05:30 PM
done's Avatar
Default Problem!
My lights used to flash when i hit my alarm, its a viper 300.
I had my fuses blown from my head unit, after that they dont flash anymore. I check every fuse.
there are two fuse boxes. Engine bay, and driver side interior correct??
Im wondering, does the viper have its own set of fuses??
Old Mar 21, 2004 | 06:00 PM
dk127's Avatar
hmm... ?!?
check the viper manual. i would imagine no because wouldn't it just send a signal for the lights to go on and off? And not actually send power itself? So it wouldn't really need a protected line. Does the Viper still work?
Old Mar 21, 2004 | 06:04 PM
Eluder200K's Avatar
Default Re: (dk127)
I think all alarms have their own fuses, I would check that out.
Old Mar 21, 2004 | 06:09 PM
done's Avatar
Default Re: (Eluder200K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluder200K &raquo;</TD></TR><TR><TD CLASS="quote">I think all alarms have their own fuses, I would check that out.</TD></TR></TABLE>
the alarm still works perfect, just the head lights dont flash when i beep it.
Old Mar 21, 2004 | 06:42 PM
mikestypeR
Guest
Posts: n/a
Default Re: (Jordo)
this happened to me on my previous car "different alarm, same problem"... i could never figure it out ... so i just gave up who really cares... its is nice to have though my suggestion is find someone that installs your type of alarms and let them know what your experiencing and they might be able to fix the problem
Old Mar 21, 2004 | 09:57 PM
Syner-G-Racing LLC's Avatar
Default Re: Problem! (Jordo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">My lights used to flash when i hit my alarm, its a viper 300.
yes the viper system has its own fuses, one is for the lights flashing when you arm or de-arm. the other is for the power lock option through the remote. there are other things tied into these fuses obviously but those are the only two things you should concern your self with.
look under you dash where the module is installed (should be close to the main fuse panel) and there should be to white fuse holders with a 30amp and probaly a 15 or25amp fuse.
you can go to DEI.com and print a manual if you dont have one.
g0tsilkk
Apr 23, 2006 08:15 PM
g0tsilkk
Mar 25, 2006 08:44 AM
comteg396
Audio / Security / Video
Dec 8, 2005 10:59 PM
mehdiR
Aug 29, 2005 07:43 AM
EJK
Aug 6, 2001 02:01 PM
