possible problem with synchros?
Old May 13, 2002 | 05:35 PM
ITR184's Avatar
Default possible problem with synchros?
Has any one else had this problem? I have to roll foward sometimes to put the car in reverse. It has been that way since I bought it new. I have also had problems with the clutch fluid. I have to bleed it periodicaly. It keeps turning black and when it does my the shifting from 1-2nd gears is almost imposible. I will bleed the system and then it is okay for about 1500 miles. I think that maybe it is a combination with the clutch and the synchros. I took it to a dealer and they couldn't find any thing wrong with it. I had to bleed it the day I took it up there though or I wouldn't have made it. I am about a 100miles from the closest dealer. I have had problems more recently going to third at 8200 rpm and 5th at about the same. any help would be appericiated
Old May 13, 2002 | 11:16 PM
EagleR's Avatar
Default Re: possible problem with synchros? (01R184)
I have the 3-4 and 4-5 prob at high RPM, and IMO its the Syncros
Jody- whos ITR goes to Acura tommorow for major warranty work!
Old May 13, 2002 | 11:55 PM
uNF$@#!'s Avatar
Default Re: possible problem with synchros? (EagleR)
i have problems with the 3-2 shifting at speeds above 30
Old May 14, 2002 | 02:05 AM
sutats's Avatar
From what I keep reading in the forums the synchro is a weakness of the ITR. I've had my 3rd gear syncrho+gear assembly warranty-fixed by Honda.
Months down the line it's happening again, I sent my car in today, they couldn't fault the crunching from 2nd-3rd. It'll only start getting worse from there. I'm just hanging out for it to grind really bad then I'll see what they'll say next. Cheers!
marcin
Jun 5, 2009 11:19 AM
fkguitar
Feb 22, 2007 04:41 AM
TEGGRY
Mar 24, 2006 04:21 AM
GsRiNtEeGrA14
Mar 19, 2006 05:22 PM
mattymatt
Nov 9, 2004 09:12 AM
