please help
Old Jan 25, 2002 | 12:48 PM
BRICKHEAD's Avatar
Default please help
I am new but I have a question I need an answer for. I have a Py ITR and I just installed my Apexi N1. I am curious as to wich hangers you guys are running, ( the upper or the lower ) in the rear. Also I am curious as to if anyone has had a rattle coming from the heatshield in the center section of the pipe. Any help would be greatly appreicated.
Old Jan 25, 2002 | 01:18 PM
Christine's Avatar
New User
Default Re: please help (itr681)
I have the Dunk on mine... similar problem with the rattle, though it's only at about 3K RPM... we bent the heat shield a LITTLE when installing the exhaust since it was rattling all the time. Should be an easy fix. just bend the heat shield a little.
You shouldn't have any serious issues with connecting it though, so if you have a ton of contact re-check your install. It should fit without any problems...
I don't remember off hand which connectors I used.
cx-sir2civic
Feb 17, 2004 03:09 PM
hYpE-R-29
Jun 11, 2003 10:27 AM
spencedogg
May 31, 2003 10:27 PM
shipsaeki
Apr 5, 2003 11:43 AM
intekragsr
Feb 9, 2002 08:10 PM
