A picture request.
Old Sep 9, 2008 | 10:34 PM
2001TypeR's Avatar
Default A picture request.
If anybody has a Type R crankshaft thats not in the vehicle, can they please take a picture of the flywheel end of it. I need to check something on it. Thanks
Old Sep 10, 2008 | 05:14 AM
Dave_B's Avatar
This is not with the crank out... but I think is what your looking for...
Old Sep 10, 2008 | 05:19 AM
get RIGHT's Avatar
Default Re: (Dave_B)
Dave's taking pics with his crank out, again.
Old Sep 10, 2008 | 05:21 AM
Dave_B's Avatar
Default Re: (get RIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">Dave's taking pics with his crank out, again. </TD></TR></TABLE>
Werd... just need some assembly lube.
Old Sep 10, 2008 | 05:23 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
Werd... just need some assembly lube. </TD></TR></TABLE>
Just dont hondabond it to your leg like that one time.....
Old Sep 10, 2008 | 05:24 AM
Dave_B's Avatar
NO way... but this time I WILL check the deck height.
Old Sep 10, 2008 | 05:26 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confucious &raquo;</TD></TR><TR><TD CLASS="quote">
You have learned well Grasshoppa</TD></TR></TABLE>
Old Sep 10, 2008 | 06:33 AM
Erik95LS's Avatar
Old Sep 10, 2008 | 07:20 AM
mugenr#1011's Avatar
Default Re: (Erik95LS)
op
is that what you were looking for?
Old Sep 10, 2008 | 12:27 PM
2001TypeR's Avatar
Default Re: (mugenr#1011)
Yes it was, im just trying to see what is directly behind the pilot bearing when its on the flywheel. Is that just another hole of the same size as the bearing it self or a slightly smaller one?
Im just wondering if theres any way to accidentally push it through the flywheel and into the crank while installing the tranny. I mean we used the clutch alignment tool and made sure the clutch was bolted in straight and the tranny went in with no problems, we double checked to see if we were hitting the splines on the input shaft and most of the grease was gone so we know we were on it.
The only thing is we couldn't seem to get the brand new tranny to slide right up perfectly to the bolts/engine, there was about only a 1/4 inch or less space, i called up my buddy who works at honda and specializes with trannys and i asked if its possible that it just needs to be bolted in slowly and evenly and he said that he has to do that once in awhile at work and that as long as the bolts go in evenly all the way around the tranny and it doesn't get super tough prematurely or bind up that it should be fine. So thats what we did and had no signs of binding or hardness and we got it secure and even.
We are starting it up today because the battery was dead
So thats why im asking since one of my friends thought we might have pushed the pilot bearing out of the flywheel into the crank as a worst case scenario, but we listened very carefully and did not hear anything pop out or making a ting sound or anything of the sort and my Honda friend told me thats usually not the case and that it would just get hard and stop us from bolting prematurely.
Sorry for long post but i guess im a bit nervous lol
Old Sep 10, 2008 | 10:58 PM
2001TypeR's Avatar
Default Re: (2001TypeR)
Update:
Anyways we started her up and it ran mint, after the initial one or 2 shifts the gears felt just like new all over again with the new itr tranny we put in there. Smooth as butter lol.
Thanks guys
earl
Performance
60
Dec 11, 2008 11:50 AM
Bense
13
Jul 9, 2007 09:03 AM
kaj
Jun 15, 2007 11:19 AM
AlexLude
Mar 7, 2006 01:45 AM
boostedbastard
Nov 23, 2003 11:30 AM
