oil problem!!!!!!
Old Mar 16, 2008 | 08:38 AM
DCnotTHEshoes's Avatar
Default oil problem!!!!!!
okay, my teg still under construction and mostly sits due to not having enough money to get it back on the road after ls/vtec build and needing other parts ... blah blah blah.... ANYWAYS, so i drive a 2000 eclipse for the time being, i recently changed my oil and oil filter 2 weeks ago, and added 4 1/4 quarts of oil, and drove around and saw my oil light came on only when the car was @ low rpms, so i added some more oil , roughly enough to equal out to 5 quarts. then i went online to research the problem b/c the light was still on and noticed people usually only add about 4- 4 1/4 quarts of oil, so i drained a full quart back out of the car and now my oil reading on the dipstick is perfect!, the car is running fine but the oil light still comes on at low rpms, when the car is warmed up. i use 5w30 (which is what it calls for). when the car is drivin the light goes away but when i throw the car in neutral or drop the cars rpms below 2k then the oil light comes on, but goes away once i rise above the 2k rpm mark.
-any help?
Old Mar 17, 2008 | 06:13 AM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Re: oil problem!!!!!! (DCnotTHEshoes)
Maybe a bad oil pump. Good luck!
Old Mar 17, 2008 | 12:22 PM
CW-ITR's Avatar
Bad oil sensor?
Old Mar 17, 2008 | 12:44 PM
citrus3000psi's Avatar
You might have a major serious problem. I would not recommend driving the car until you can verify your oil pressure.
Get an oil pressure guage to verify you are at the right levels.
DCnotTHEshoes
Mar 16, 2008 04:27 PM
EFz6er
Dec 28, 2004 01:39 PM
Foxcow
10
Dec 16, 2004 08:56 PM
hondaracing1
Mar 27, 2004 05:38 PM
